    chips & bier
    Reputation: eric's Avatar
    Altitude '13 single ring chainguide options
    I'm orking on a couple of drivetrain changes on my Altitude. The 2x10 + clutch derailleur works okay but still contemplating a single ring setup....
    I just noticed RMB specs an E13 XCX guide on the 2014 Altitude 799 using the swingarm S3 derailleur mount, rather than the ISCG tabs. Anybody have an idea why?
    (May end up just sticking with 2x10 and one of these TRS Race Dual Guide | the hive )
    ups and downs
    I imagine they just had to pick one, they are both about the same cost and weight, maybe a coin toss. Although more likely it was the speed at which it goes on the bike in final assembly that would favour a two bolt mount over a three bolt.
    Use one of the Race Face narrow/wide rings and you can likely ditch the chainguide on a 1x10.
    Reputation: skyak's Avatar
    I ordered a Wolf Tooth direct mount for my '13 Altitude, no chain guide.
    Direct Mount for SRAM GXP Cranks | wolftoothcomponents.com
    chips & bier
    Cheers, thanks for the ideas! Will probably end up going for a narrow-wide 34t and an S3 mount as absolutely required
  1. Single ring chainguide for HD (not HDR)?
    By Stripes in forum Ibis
    Last Post: 07-11-2013, 05:59 PM
  2. Single ring chainguide for current Chameleon?
    By elmono in forum Santa Cruz
    Last Post: 12-21-2011, 03:01 PM
  3. Have SLX triple crank, want to go Single ring w chainguide
    By ride the biscuit in forum All Mountain
    Last Post: 06-26-2011, 02:42 PM
  4. HELP! have SLX triple cranks and want to go single ring with chainguide
    By ride the biscuit in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-24-2011, 06:24 PM
  5. chainguide for 28t ring
    By chenpj in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-21-2011, 06:19 PM
