Hello All,
I've installed a Specialized command post IR to my 2014 Instinct but i've run into difficulties. Unlike the reverb the outer cable needs to be kept static in order to keep the prevent the inner cable slackening.
The problem is I have to leave some slack in the cable running from the handlebar remote to the point where the cable enters the frame in the head tube, but because there is no way of fixing the outer, means it slides back through the frame and therefore slackens the inner cable so it won’t operate.
I have attached two pictures, where you can see I have botched it at the moment with some duct tape but this only works for while and I wanted to see if you had any suggestions as to what I could do as this must be an issue with any cable operated seat posts.
I'm probably just being thick but if anyone can make any suggestions or has solved similar problem, any words of wisdom would be much appreciated
