Results 1 to 3 of 3
    May 2005
    2014 Altitude - Shock upgrade. Where to get the right Float X or will a CCDBA fit?
    Hi, I am looking for an all carbon Altitude with proper All-Mountain shock like the Rally Edition.
    I think about getting a 799 MSL frame and change the swap the shock for a Float X or CCDBA.
    Now, where to get the Float X CTD which comes with the Rally edition? I think it is custom shimmed so an Aftermarket shock probably wouldn't work as good as the stock one.
    Another shock option would be the Cane Creek Double Air. But will it fit the Ride9 hardware?
    ups and downs
    The Rally Edition seat stays are also a different shape where they meet the shock and swing link.
    770 MSL Rally Edition
    Standard 790 MSL
    Name:  Altitude_790_MSL_Side (1)-001.jpg
    May 2005
    I think that is only because of the other Ride9 position on the Rally picture. If you look on other pictures you can see that the seatstays should be the same.
  1. Replies: 15
    Last Post: 09-23-2015, 01:10 AM
  2. Convert 2014 Fox Float Evolution CTD shock to use remote
    By Chris_F97 in forum Shocks and Suspension
    Last Post: 03-06-2015, 04:11 PM
  3. CCDBa or Float CTD?
    By ryan_daugherty in forum All Mountain
    Last Post: 08-06-2012, 11:01 PM
  4. Clydesdale here - Will I need to upgrade my Float R frame shock?
    By shwndh in forum Shocks and Suspension
    Last Post: 04-02-2011, 12:43 PM
  5. Altitude 70 RSL Shock Upgrade
    By e.eddievasquez in forum Rocky Mountain
    Last Post: 01-11-2011, 02:46 PM
