2013 Instinct FAQs
Printable View
  • 04-13-2014
    Jr1978
    Originally Posted by rockyuphill View Post
    Bare wheels with hubs, spokes, rims and rim strips only. I replaced mine with Enve carbon wheels at 1415gms. Boy did that make a difference.
    Enve wheels look awesome but the cost makes it hard to justify.
    I'm amazed the Stan's flow ex would apparently both be wider (stiffer?) and lighter than the m1.6
  • 05-26-2014
    gregmazo
    Digging this thread out.
    As far as sizing goes.
    I am 5 11.
    I guess large would be better than medium. WHat are your opinions.
    Cheers.
  • 05-26-2014
    rockyuphill
    At 5'-11" you're right on the cusp between M and L. If you want a longer feel, then the Large would e the way to go. Compare the HTT length with other bikes you own to get a sense of how it will compare
  • 05-29-2014
    Sweetness
    I would suggest you're definitely a large. I'm 6 feet and 1/2 inch and the XL frame fits like a glove with a shorter stem. If you go for a medium, I'm not sure you'd be able to get the seatpost high enough to get proper leg extension.
