Results 1 to 3 of 3
    2012 element 930 travel change question
    So during the maintenance of my stock recon fork i took out the 20mm spacer to change the front end from 100mm to 120mm. I did notice something odd though I now see 130mm when I measure the upper gold stanchions. Is this a cause for concern? Am I stressing the bike frame too much or am I measureing the wrong thing thing or too OCD? The recon manual does say removing the spacer should make it 120mm so I'm confused. Any help would be appreciated.
    ups and downs
    There should be about 10mm of free stanchion length to help prevent hitting the tire with the crown at full travel, if you would have measured the fork before removing the spacer it should have shown 110mm of stanchion.
    great! thanks for that. Nice to hear I was worrying over nothing. plus I learned something today!
  1. Element Change Of Travel
    By Mederz in forum Rocky Mountain
    Last Post: 09-14-2013, 08:33 PM
  2. Change Travel on 2012 120mm SID XX?
    By boyReid in forum Shocks and Suspension
    Last Post: 07-10-2013, 03:39 PM
  3. 2012 Reba 29 RLT Travel Change
    By TheHamster in forum SRAM
    Last Post: 03-24-2013, 06:27 AM
  4. 2012 Element 970 SID fork travel?
    By field_c in forum Rocky Mountain
    Last Post: 10-09-2012, 03:08 AM
  5. Question about fork travel on 2012 Element MSL 70
    By Sweetness in forum Rocky Mountain
    Last Post: 04-12-2012, 02:49 PM
