Results 1 to 2 of 2
    JeffcoHo
    Reputation: JeffcoHo's Avatar
    2010 Rocky Mountain Slayer Front derailleur interference.
    So i have a XTR front derailleur on my Slayer. During adjustments sometimes the set screw that pins the cable hit the frame of the bike as it swings. In addition if the suspensions is loaded it will block the arm from swinging.
    Are there any front derailleurs that fit really well on that generation of slayer? Or do you find a set screw that is not as proud?
    ‎"Reject your sense of injury and the injury itself disappears." -Marcus Aurelius
    ups and downs
    Is this a Slayer SXC? If you're running two chainrings and a bash then an SLX 2 ring 9 speed FD fits better.
    Does your swingarm have this notch in it to clear the FD screw?
