Results 1 to 3 of 3
    Feb 2006
    2009 Flatline Pro problem
    Curious if anyone has seen this before, I recently got a complete Flatline Pro, everything is fine except that the clamps on the rear dropouts have been cranked in very hard and all the bolts have been stripped. Its starting to sound like my only option is to have them drilled out.. and not even sure what to get to replace them
    Were the bolts so tight that you stripped them trying to unscrew them? Regardless, drilling them out should be pretty straightforward.... the bolt you need is an M5 and approx 15mm long.
    did you try a heatgun and an easy out. that will work wonders
