Results 1 to 10 of 10
    Reputation: kameraguy's Avatar
    2008 Slayer SXC: shock specs
    Hi, can anyone please let me know the length and stroke shock for a 2008 SXC? Tried searching for this info here but my search skills are probably very poor (extremely likely).
    Thank you.
    oops, nevermind, I searched a different way and found the answer: SXC: 7.875 x 2.25
    sorry for the beginner question - were you looking for the front suspension spec ?
    as i got slayer scx 50 and im looking for this info
    ups and downs
    The SXC-50 would used a Fox 36 Float 160 R fork.
    is it Air fork ?
    what do you think about RST for sxc50 ?
    or Rock Shox ?
    ups and downs
    Fox Floats are all air forks. Rock Shox Lyrik Solo Air also work well on the SXC-50.
    I wouldn't waste the money on an RST for the SXC-50, not in the same league, they won't keep up with the Fox rear shock.
    You also don't want to go any shorter than 150mm of travel or you start to change the geometry
    thanks for you answer !
    cheers !
    would you go for 120 / 130 / 150 / else ?
    ups and downs
    Nothing shorter than 150mm to maintain the geometry.
    thanks again
