2007 Slayer sxc 70 pivot/linkage bolts
Bought s/hand Slayer 2007 sxc frame and the pivot and linkage bolts need replacing, was wondering if any one as used something other than the standard bolts, as I am not sure how easy it will be to source them in the uk.
Rocky have a new distributor here in the uk and I will try them, but was wondering if I could use standard off the shelf bolts depending on availability and cost of the Rocky ones
You'd likely grow old and grey trying to find off the shelf hardware to match, especially the alloy pivot axles. If the distributor can't supply the old bolts kits, you can always contact Rocky through their online store website.
Already old and gray, kind of what I thought, will give them a try
I'm also looking for the pivot/linkage bolts. Did you find something?
Just spoken to a guy at the UK distributors, they have a service kit that contains everything but the pivot bolts, but he seems to think he can get them, also had an email from Bruno Roy at Rocky Mountain and he says they have them in stock and gave me some part numbers which are 180370AUT-006 & 180350AUT-067 but I am not sure which part number relates to which bolt. I am starting to think that it might be quicker and cheaper to get some replacements made at a local engineering company.
The service kit without the bolts is £143.00.
Those are bolts from the 2010 Slayer SXC (see attached image and list - in German). The 180350-067 are the M12 x 67mm bolt for the main pivot and the 180370-06 is the flange nut for that main pivot bolt.
They'd be items 14 and 15 on the 2007 SXC drawing and parts list below and items 5 and 6 on the 2010 SXC diagram.
If you open the images in a new tab or window they will be the full size and you could send them along to the UK distributor to let them know the number of the bolts you need.
By onwheels in forum Marin
Last Post: 10-19-2013, 02:01 AM
By huckgnar in forum Intense
Last Post: 08-24-2013, 02:10 PM
By jonasrullo in forum Hawaii
Last Post: 11-17-2012, 02:51 AM
By snowbeard in forum Rocky Mountain
Last Post: 05-18-2012, 05:02 PM
By Olyoyster in forum Niner Bikes
Last Post: 05-12-2012, 09:05 PM
- You may not post replies
- You may not edit your posts
Forum Rules
