Results 1 to 3 of 3
    Syncros Thomson seatpost part compatability question...
    I have what is hopefully a simple question that I haven't been able to find an answer to. Maybe I am just looking in the wrong plce.
    I recently aquired an older Syncros seatpost. It is the titanium model with the double bolt clamp style. Below is what it looks like.
    Will Thomson bolts and pins work in this style of clamp?
    Yeah, it might only save a gram or two but then gain, this is the Weight Weenie section.
    Thanks in advance.
    What's "social pace?"
    I think Toronto cycles carries the hardware for both. I do believe the barrel nut things are interchangeable but the bolt length may be longer on a thomson. I believe this also applies to the Easton ec90.
    Quote Originally Posted by dinoadventures
    Thanks for the info. They have just what I need! I knew I was just looking in the wrong places.
    Cheers!
