Results 1 to 6 of 6
Thread: Syncros Stem Q'
    illuminaughty
    Reputation: da'HOOV's Avatar
    Jan 2009
    Syncros Stem Q'
    Almost every alloy Syncros stem I've seen has a weld "bump" like this in the same spot. Anyone know why? I assume it was where a rod was tacked to it for holding on and rotating during construction?
    Reputation: 57-180's Avatar
    That my friend is the infamous "Power Zit" Not sure on the functionality, but I always figured it was where the welding started & finished. I believe that "Power Zit" was the coined Syncros term.
    Looking for 58cm Road Logic or Road Classic
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    That's where the weld started and ended when they produced the stem. They built up the zit with extra filler rod to prevent it cracking thru there.
    I don't post to generate business for myself or make like I'm better than sliced bread
    illuminaughty
    Jan 2009
    thanx guys...thats kinda what I thought but I didn't know it was for strength....
    oh and on this note
    if anybody has a 125 or 130 positive rise in black they are not using please PM me.
    Mebbe they stopped the weld and stuck the filler rod there. Snap it off, file it smooth. Kinda odd either way.
    -Schmitty-
