Results 1 to 8 of 8
    Ritchey Superlogic carbon seat post
    Anybody have a verified weight for the Ritchey Superlogic carbon seat post in a 30.9 x 400 ?
    Racerick
    "The older I get, the faster I was"
    gone for a bike ride
    Reputation: culturesponge's Avatar
    WCS Superlogic 30.9 x 400mm
    this one is 30.9 x400mm with a Ti bolt
    it was somewhere on here: http://www.forumbtt.net/index.php?PH...opic=15933.300
    both my frames use a 30.9 post but i decided to purchase 27.2 and use a 14g modded USE plastic shim to fit
    my 27.2 x 350mm Superlogic is 151g with a Ti bolt, a SLR Carbonio wide rail kit adds 7g
    well that certainly answers my question
    Thanks !
    Racerick
    no probs racerick
    Ti-bolt
    Culturesponge,
    The seatpost comes in with ti-bolt or you bought one. Where did you buy the ti-bolt?
    akazan, here's http://www.mettec.com/ my source for ti hardware
    Racerick
    both my WCS 1-bolt posts came with steel bolts - suprisingly as equally spendy WCS stems come with Ti fasteners
    so i bought a couple TiN coated M6x50mm from here http://www.tekbolt.com/products.asp?cat=60
    ...but they were 5mm too short to use with a WCS 1-Bolt Carbonio SLR wide rail kit (but would be okay without wide rail kit) so i tried again with plain Ti M6x55mm bolts from my fave Tom @ Toronto Cycles dot com - now no problemos & 7g lighter.
    with the rail kit it takes a 55mm huh ?
    cool, i already have one of those
    Racerick
