Results 1 to 6 of 6
    Ritchey Superlogic carbon bars vs. WCS carbon
    I'm running the WCS carbon right now and I like it a lot, but I need another one and now I see there's the Superlogic carbon on Ebay for $120 with a claimed weight of 145g for 31.8 660mm.
    Anyone using this bar? Comments? Comparison to WCS carbon?
    Rigid bikes FTW!
    Dec 2008
    I'm running that bar in the low rise -15mm,however it came in at 160 grams.Same crap as the Easton stuff, weights all over the map.On elite top of line products I could except 2-3 % variance, but 10-15 % on all this Ritchey & Easton stuff is a joke.I believe that bar retails for around $350.00 cnd.Besides the weight I'm happy with the bar,nice width & the rough sandpaper like finish for the stem clamping area is great.I torqued Ti bolts with antiseize at 3 Nm & the bar doesn't move & the bolts stay put.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Easton Monkey Lite XC 31.8 Lo-Rise - 179g, $75 from Jenson.
    Santa Cruz Hightower LT
    EVIL Following
    Quote Originally Posted by MI_canuck
    What does that have to do with a comparison between WCS carbon flat bars and Super Logic carbon flat bars?
    As far as I can tell, the Superlogic bar is lighter because it doesn't have the metal inserts.
    Actually I was talking about the low-rise (15mm) bars, but I'm sure the same difference applies to the flat ones.
    Rigid bikes FTW!
    Reputation: iClique's Avatar
    Not much weight difference... 10g and the WCS Carbon weave looks much better than the UD look of the SuperLogic
    SuperLogic Flat Carbon 580mm 31.8mm 5 125g UD Carbon 169.95
    WCS Mtn Flat Carbon 5D, O/S 31.8 x 580mm, Blk 580mm 31.8mm 5 135g Carbon 139.95
