Results 1 to 25 of 25
    Master of the Face Plant
    The Ritchey project is done.
    Well it is not period correct but it isn't too far off. I opted to use xt st-m0950 8 speed shifters. Of course my rear hub won't take an 8 speed cassette so I just used a 7 speed and set the limit screw. To my suprise it works perfectly. Shifts are nice and smooth. The DX wheels are off a newer bike and the King headset is new. I must say I am pleased with the way it turned out. It rides great, it is very light and it is very nimble. The maiden dirt voyage is tomorrow. Here are the spec's:
    Frame: 1988 Ritchey Ultra
    Shifters: Shimano XT st-m0950
    Front brake: BR-m730
    Rear brake: XT U-Brake
    Front Derailler: XT FD-M730
    Rear Derailler: XT RD-M730
    Wheels: Matrix Single Track Comp on DX Hb-650 Hubs
    Skewers: Odessey?
    Seatpost: Strong Japan
    Saddle: Selle Italia Flite Titanium
    Cranks: XT FC-M737
    Headset: King
    Tires: Panaracer Timbuk II
    Pedals: XT PD-M730
    Handlebar: Scott AT-2 LF
    Cables: Gore Ride On
    Cranks Bolts: Adventure Components.
    http://www.nbbikes.com/
    ^^^Best Bike Shop of MTBR 2008^^^
    Sharp!
    -Schmitty-
    Reputation: sho220's Avatar
    Aug 2005
    Very nice looking build. I believe the skewers are Odyssey Svelte...not super light but solid and easy to open/close...
    Reputation: yo-Nate-y's Avatar
    I see you have two pie-plates
    Mis-mash it may be, but I like the Ultra. The bars....not so much. But I dig the skewers!
    Somec is like the digital Zunow
    And this: http://www.youtube.com/watch?v=JD5h3y0a9AU
    If anyone needs decals open this PDF and fill out the order form. Then just fax it to Ritchey. The number is in the PDF.
    RITCHEY DECALS.pdf
    Quote Originally Posted by yo-Nate-y
    I have the original wheels but they need service. They still look great so eventually they may go back on. I figured I would give the bar a try but it is a bit strange to me. I have the Titec that came on it but I lost the shims. When I find them it may go back on with the bar ends. I also have the original spec xt thumbies and brake levers and cranks so if I ever decide to go the purist route I am set.
    I know those bars well.......my first 'real' mtb purchase was the Scoot bars that wrapped all the way round with an aero thumbtucker in the middle. Yipes. With the early curve I always found them a bit too narrow.
    Sep 2004
    Nice looking bike! I use that same crankset on my drop-bar 29er (as a 1x9) and although they are newer mid 90's vintage they are great performing cranks and are really ultra-light (arms alone 475 grams on weight weenies) without being flexy. At any rate enjoy & congrats on a nice build!
    JR
    Quote Originally Posted by N10S
    JR
    They are actually prone to snapping on the drive side right at the spider transition.
    IMHO, that vintage xt was the worst ever....
    -Schmitty-
    Quote Originally Posted by Schmitty
    -Schmitty-
    Well thats not good. I am a big guy too so it looks like my M730 cranks will go back on there if I can ever find them. Heading out for a ride right now though so I hope they last at least that long.
    artistic...
    Reputation: colker1's Avatar
    Quote Originally Posted by sandmangts
    i have an LX crank same vintage on a bike and it's been 13 yrs of straight on abuse.
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    Sep 2004
    -Schmitty-
    I appreciate the info, but in all these years of riding have never heard that. I have had four bikes fitted with the 737's over the years and never had an issue of any sort. At 175-180 lbs I am not a lightweight, but not over 200 lbs either. So I have had nothing but good luck with those cranks and that's what fueled my comments. I certainly listen to all feedback so if they are known to "snap"at the spider then that's a concern. I am sure I will be thinking about it every time I am powering up a hill now! .
    I am at 192 lbs and I do have a tendency to break things, usually seatpost bolts and chains. Todays maiden ride was a learning experience. The 7 speed shifts very nice but I am used to sram x.9 so I kept missing shifts. I was able to climb everything considerably faster than any other bike I own. The Timbuk tires have good bite in the corners and they did not slip much when I had to get out of the saddle on climbs. The bars are nice because you have a lot of different positions but they are too narrow so I will change them.
    The best thing about this bike is the low maintenance. No adjusting shock pressure, rebound, sag, or lockouts. No bleeding brakes or tubeless sealant mess. Just build, ride, adjust, ride more and keep riding. Nothing you can't fix with just a multi-tool in most cases. It is perfect for my local rides where my Epiphany is just overkill.
    Made a few changes
    I swapped out the crank for a M730 and swapped the bar. Handling is much better now and I can still change my hand position. I have tendonitis and I get alot of pain in my forarms if I don't change position often. The only problem was the UN-72 bb I had was too short so I had to use a longer UN-52. Now the chain is a bit too short but thats an easy fix. Nothing beats riding something you built.
    artistic...
    [QUOTE=sandmangts] Nothing beats riding something you built.
    good stuff sands.keeping it real.
    Reputation: gm1230126's Avatar
    RITCHEY DECALS.pdf
    Not nearly a complete selection but they all do still exist....
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    John Galt
    Reputation: cegrover's Avatar
    VERY nice! Good to see the rear brake's in the right place, too...
    Quote Originally Posted by cegrover
    I had a hell of a time adjusting the u-brake, I had never done one before but I finally got it. And Ringle bottle cages may look cool and be light but they suck. Hard to put on, fragile and require adjustment to hold the bottle. The Timbuk tires from First Flight are really nice though, they look right and are a great all around tire.
    Reputation: Fillet-brazed's Avatar
    I would say the U brake is probably the easiest mtb brake to adjust by far. Maybe the method of setting the spring tension threw you?
    Regarding the Ringle cages, I don't even think they look cool, all those bad things you mentioned notwithstanding. Especially on a Ritchey. To add to the nostalgic coolness you could add a Ritchey seatpost, normal bottle cage, Turbo/Ritchey saddle, Ritchey rims and some more conventional (less loud) bar ends maybe.
    Edit: Oh, and those skewers, save them for some mid-90s bike or some bike you don't like.
    John Galt
    Quote Originally Posted by Fillet-brazed
    Or just ride and enjoy. I say to each his or her own. Personally, I chose period-correct for my Crazy Pete, but I have plenty of respect for:
    1) The idea of having period and slightly later parts. That's how it is with owners that keep frames a long time and upgrade/replace parts over the years and,
    2) Using what works and riding the bike.
    yep. my comments were: "to add to the nostalgic coolness"...
    by the way sandman, aren't those particular shifters you have 7 speed shifters and not 8?
    The brakes are actually easy it was just me having the bolts too tight for the spring tension to work right. once I got it figured out I felt stupid. Some parts will change over time. I have the original rims but they need work. I am looking to trade for a correct post and saddle. Already posted in the trade only thread. It will evolve over time I just don't have all the parts available. I just couldn't wait to ride it. The good thing is selling some of the non-period correct parts should more than pay for getting the right ones. As always thanks for your opinion.
    John Galt
    Very good point. Hopefully, you know where I stand - plenty of respect for your views/knowledge and those of other purists (that's NOT an insult)...
    That is correct, initially I thought they were 8 speed because they were shifting past the top ring but setting the limit screw fixed it. It was weird becase the grease in them was so gummed up you couldn't feel the clicks. Some wd-40 and fresh lube and they work perfect now.
