• 04-18-2011
    ritchey_dave
    New Old Stock 1999 Ritchey NiTi frames
    We found a bunch of these unfinished in our warehouse. Sent them to D & D (the people who have painted our frames from practically day one) to get a fresh coat of basic black and now they're available to you! Size 21 only.
    They're available at www.bikewagon.com
  • 05-22-2011
    ranier
    If only you had a couple small frames...
  • 06-14-2011
    pindowngirl25
    What size fork would that take? Specially AC length.. For rigid..
  • 06-15-2011
    ritchey_dave
    They accept 1" threadless forks. As far as AC length, I'm not sure. If you contact Bikewagon someone there could find out for you.
  • 06-19-2011
    Fred Smedley
    The Bikewagon description is claiming 1 1/8 fork which would be appropriate for a 1999 frame.
  • 06-20-2011
    ritchey_dave
    Whoops. Sorry about that, I checked one here at the office that apparently is different from the ones we sold Bikewagon. 1 1/8 is correct, sorry for the confusion. Lesson here, Bikewagon knows more about this frame than I do at this point.
  • 08-14-2011
    jfn3
    Find a 56cm Road Logic!
    If u build them they will sell! lol
  • 08-15-2011
    ritchey_dave
    Stay tuned!;)
  • 01-02-2013
    kaipaki348
    Hi Ritchey Dave.
    Just got one of these frames. Currently being shipped. Can you please confirm, is the seatpost a 27 or a 27.2?
    Thanks for your help.
  • 01-04-2013
    ritchey_dave
    Hmm, not sure without a model year. Where'd you get it from. Did you check with the seller?
    edit:
    HA! Probably the one that's the subject of this thread! Sorry, too many long days. That's a 27.2 seatpost.
  • 01-10-2013
    kaipaki348
    It's one of the frames from bikewagon. All sorted tho thanks.
    Another question... If I was to run a rigid fork what axle to crown length would you recommend to keep the geometry correct?
  • 01-10-2013
    ritchey_dave
    Find something suspension corrected for 80mm.
  • 01-10-2013
    kaipaki348
    edit:
    No problem. I suffer from that too.... Is it 27.2 or 27?? After posting I saw that it stated 27.0 on bikewagon.
    Also, do you know the axle to crown length for a 80mm corrected rigid fork and can you recommend where I can get one from.
  • 01-11-2013
    ritchey_dave
    410mm
    You'll have to hunt around, I'm not sure who has something like that, but it's pretty common for rigid 26" forks. We used to make a carbon rigid fork that would work, there's probably still some floating around. I think Bikewagon bought the last of them, they might still have some.
