Results 1 to 26 of 26
    used to be uno-speedo....
    Reputation: dirtdrop's Avatar
    Help identifying material of Syncros seatpost
    I have a Syncros seatpost here and I'm wondering if its aluminum or titanium? After searching the intardweb I've noticed that the ti version has a titanium decal but as you can see from my photos, the decals are rubbed off some what. I've also seen a ti model where there is a hole drilled out at the bottom of the seatpost. Is this typical of a ti Syncros post?
    Is there a trick to identifying the material? Can you tell by the head clamp?
    FWIW the size is 29.3 x 330
    I've run a couple of searches and haven't come up with anything. Probably using the wrong terms.
    VRC Hound
    Reputation: bushpig's Avatar
    29.3? What is that for?
    Reputation: laffeaux's Avatar
    Yep, looks Ti to me too.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Reputation: Williwoods's Avatar
    the top clamp is aluminum the shaft is titanium I had one like that and they are very nice posts..
    Quote Originally Posted by bushpig
    ti.
    thanks! how can you all tell?
    i meant 29.4
    like I said above I should have been a little more clear, Aluminum has a pale silver color like the clamp of your post. And Titanium has a almost platinum or dark grey color like the shaft of your post. When they are side by side its super easy to tell.
    Reputation: Fillet-brazed's Avatar
    Quote Originally Posted by uno-speedo
    i meant 29.4
    The color. Very easy to identify to the trained eye.
    Flick it at the end with your fingernail and and compare the ring to aluminum post's thud.
    Thank you both kindly.
    VRC Hound
    Quote Originally Posted by Fillet-brazed
    Also the wall thickness, not pictured, and the fact that I am not aware of Syncros making a champagne ano post.
    velocipede technician
    Reputation: hollister's Avatar
    look for white sparks
    looking for 20-21" P team
    also, any shavings under half a square millimeter will fall twice as fast as aluminum's.
    As far as I know the 29.4 fits various Ibises and Fats.
    yup
    you can see the difference in pic 2. pretty obvious the difference in material
    plus I don't think Syncros made a Silver Alu post. I could be wrong but only remember black.
    Maybe some silver Alu in the mid to late 90's. By 98 most of the line was Black
    PMK
    PMK is offline
    Reputation: PMK's Avatar
    Post is ti as others mentioned, I'm more curious about what vintage or year they think it is. The two Syncros posts in our house are both mid 90's. The clamp setup is quite different.
    Ours have a top clamp with much more thickness and is hollowed out, same for the lower clamp. Also the upper clamp on ours have round barrel nuts, allowing the fasteners not to bend as the clamp is tilted.
    PK
    Reputation: DoubleCentury's Avatar
    I hope you now get top dollar for it.
    Reputation: gm1230126's Avatar
    90 and 91 Xizang's also.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    VRC Hound
    Quote Originally Posted by DoubleCentury
    Trained eyes can determine materials and pumping for info to sell!
    Moderators privilege, no?
    VRC Hound
    We are democratic here.
    No known cure
    Reputation: Vader's Avatar
    Just in case anyone cares, Thomson and Syncros saddle clamps are interchangeable.
    Ripping trails and tipping ales
    willy2004
    Guest
    So much for the alleged wrongness of mining the board for info, failing to state your intent to list the item on ebay then proceeding to do so http://cgi.ebay.com/ws/eBayISAPI.dll...m=120370483608
    Quote Originally Posted by -Anomie-
    True. It's one thing to state your intent up front and let everyone know you need info on a bike you aren't familiar with to create an accurate auction. Some may be willing to help out, others won't, but at least we all know what's going on. In the past, we've had people "mine the board" for info as if they were a new collector, and then turn around and put direct quotes from posts here in their ad. We are all happy to help out anyone new to the VRC "scene", but we generally don't take kindly to those who are only interested in profiting from freely given info.
    http://forums.mtbr.com/showthread.ph...04#post5290804
    Kind of like the Moderator is doing?
    btw, I am in favor of discussing vintage bikes even if the bike may be for sale on ebay or CL. I don't mind one bit if you profit from the auction (hope you do) and hooray for having an accurate and informative item description. This is good for everyone.
    I guess I should thank you for posting my listing? More exposure, thanks!
    It was a genuine question. I fail to see what is wrong with that? At no point did I state that I was selling it. If you check my post history you'll see that all my for sale ads are posted with a paid MTBR classified ad. Not a moderators benefit. Like we get anything anyway.
    willy2004
    Guest
    Quote Originally Posted by PMK
    PK
    Yours sounds like mine which is the same as the one pictured on this Bike Pro page http://www.bikepro.com/products/seatposts/syncros.html I am guessing that the OP's is a very early model...it sure looks very Syncrosish.
    illuminaughty
    Reputation: da'HOOV's Avatar
    Jan 2009
    It was a genuine question. I fail to see what is wrong with that? At no point did I state that I was selling it. .
    hey, I've used that defense and it has never worked for me .....but I've recieved PM's later asking me to sell
    VRC Hound
    Quote Originally Posted by willy2004
    The OPs post is slightly later Syncros design too. The early ones looked like IRD. So much that Rod Moses called them up and asked them to change their design.
