Results 1 to 7 of 7
    Slow riding mama's boy
    Reputation: Billy Zoom's Avatar
    Does Ritchey WCS 4axis 44 stem have ti bolts?
    Hey, folks.
    Just wondering if any of you knew whether this stem uses ti hardware or not. I couldn't find any info. Thanks for any help you can provide.
    Reputation: Tiffster's Avatar
    No uses steel bolts.
    Reputation: bholwell's Avatar
    Oct 2007
    Should make for a very light stem. I plan to buy it myself.
    http://www.mtbti.com/catalog/viewDetails.asp?pid=80
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Wow, the weight of a four bolt clamp with none of the benefits...thanks Ritchey!!!
    I asked Ritchey the same question.
    Only the WCS Matrix Carbonalloy 4-Axis O/S Stem has Ti bolts. They are Taper head Titanium bolts.
    I asked Ritchey if I could add Ti bolts to my regular 4-Axis stem and they said yes - use good judgment, good quality bolts and Ti prep. Also check the torque.
    They do not sell them (Ti) as an upgrade.
    The WCS Carbon 4-Axis is the only stem out of 20 that they use Ti on. The rest are very high strength stainless steel.
    I asked for the engineering specs on the bolts - but of course they wouldn't release that info.
    Reputation: Broccoli's Avatar
    Quote Originally Posted by ericsan256
    What is the size (I am too lazy to go and get calipers..)
    Quote Originally Posted by Curmy
    I did the change on my stem, I believe they are M5x17.5 (possibly M6 but I can't remember off the top of my head). There is a thead over at ww.
    The only issue that I had is that there were some convex washers on the original steel bolts that create a flat surface for the bolts to sit on (stem holes have concave shape). But I wasn't able to just slide the washers off the steel bolts.........so i ended up cutting the old bolt heads off. The Ti bolts fit nice and snug now.
