Deore LX equipped bike that I spec'd for the 1995 model year had them. Anyone that wanted to spec them could. All one needed to do was tell their factory that's what they wanted. Of coarse there was an upcharge.
Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
So I think the consensus would be "lot's of builders used them, doesn't really mean much. They were easily specced and readily available to whoever wanted dropouts"
"nothing stan likes more than.... wallowing in his obnoxious self-righteousness" 6-2-12 Bushpig
I have a set of Ritchey rear dropouts that I ordered from QBP back in '92 or '93. Why? Dunno. They were cheap, and I guess at the time I thought I had some use for them. They were around $10-12 then if I recall correctly.
I mention this just to underscore that this is not a useful metric for frame identification.
That is a nice looking frame. I suspect that the cable stops, seatpost cluster (and seatpost diameter) and any markings on the BB shell would be a good place to look for help in ID'ing it. Those are kind of interesting top tube cable stops, kind of distinctive. Maybe someone will recognize them?
Looks like a DKG seat binder, but again ... that doesn't help narrow it down much. Lots of builders used them, as well as aftermarket sales.
Sticker with only the main frame tubes showing as Chromo would imply that rear triangle was lower quality hi-ten steel...
I seem to remember a lot of 80's bmx'ers built that way.
Some more pictures of my wife's bike (sorry for minor thread hijack):
View from the rear showing fillet work on brace and Salsa-esque rear canti stop:
Somewhat unusual chainstays - tapering oval-to-round tubes with flat sides on the oval section:
Very clean tig work at the headtube:
I just love the way the builder mounted stops to produce this perfect fan of cables when viewed from the drive side:
The smooth transition from stays to dropout is very similar to Rumpfy's beautiful Potts, would probably look even better with something better than its current rattlecan paintjob:
Steve
Not really. Most frames with a tubing sticker only have one, on the main triangle.
mtbtires.com
