    Is this a fatal injury to my '03 HP??
    Well, my backup '03 HP has been seing some use lately. Today, I noticed a significant injury, which must have occured on my mid-dfay ride. The dent is located on the rear of the set tube, and was a consequence of the link support contacting the seat tube during compression. I looked carefully for cracks in the welds, but I have not been able to find any. My question(s) are:
    1. Given the current location/severity of this sent is the frame safe to ride?
    2. If this is a fatal injury, would one consider it to be a warranty issue. I am assuming that this is the same type of injury that caused the now infamous '03 frame cracking epidemic...
    I have attached some images that may assist in diagnosis:
    Uhhhhh...
    Reputation: TheSherpa's Avatar
    Quote Originally Posted by erichwstein
    Did you put a different size shock on than stock? If not, it's def. a design flaw and should be warranties. Come on Dave!
    Fayetteville, AR and N.W.A RePrEsEnT
    On MTBR hiatus :(
    Looks like you still have the original 5" travel linkage installed.
    IH made the now standard 4.5" / 3.75" linkage plates available to solve this problem, which, by the way, only affected a particular batch of frames (my '03 Hollowpoint plays quite well with the 5" linkages).
    Be sure to email IH if you haven't already.
    speedub.nate
    MTBR Hiatus UFN
    Quote Originally Posted by Speedub.Nate
    Nate,
    Thanks. You are correct, they are still the original linkages. It has been riden for 2 years with no problem until today. I will be sure to email CS. By the way, whom should I contact??
    Thanks again,
    Erich
  1. Hayes Disc on 03 S-Works Epic - Help!
    By VTSEAL in forum Brake Time
    Last Post: 06-08-2004, 09:56 AM
  2. Disc mounting on '03 S-works Epic - HELP!
    By VTSEAL in forum Specialized
    Last Post: 04-27-2004, 10:00 AM
  3. 03 vs 04 S works Epic frames
    By WOY in forum Specialized
    Last Post: 04-13-2004, 12:37 PM
  4. '03 Specailized Epic or '04 Stumpjumper Comp?
    By Theadict in forum Bike and Frame discussion
    Last Post: 03-30-2004, 12:48 AM
  5. could 03 stamped be 04 forks?
    By greenchops in forum Shocks and Suspension
    Last Post: 03-17-2004, 06:13 PM
