Results 1 to 7 of 7
    Reputation: wsmac's Avatar
    CAUTION! A rather self-indulgent narrative… ;)
    Had a somewhat painful, yet invigorating and strengthening hour and a half.
    I am a week out from a moment when muscles, ligaments, tendon, skin and bone were put down rather hard onto solid, rocky ground resulting in prolonged pain and minimized ability to move freely in my right shoulder.
    Confounded by pain in my upper ribcage just dissecting my right armpit, I guarded, babied, that arm and shoulder.
    Might sound pretty bad, maybe melodramatic… but it wasn't all that bad… yet it still hurts and has kept me from doing something so simple as raising my right arm to nipple-height without pain and sometimes with total loss of muscle control such that my arm would drop partially or all the way. Sort of like a switch being swung from the contacts, resulting in a flash of electrical arc and subsequent power loss, the machine dependent on that power swinging down into a state of rest no longer able to complete it's task.
    So here I am, day 2 of my personal rehabilitation, rotating my arm through it's various planes of movement, testing, seeking a path around and/or through the pain.
    The movements I make are slow and deliberate, allowing me to gauge the ease or difficulty of my ability to make my arm move through the line I have chosen, but ready to alter it slightly or stop all together if the pain becomes too much, or that switch is thrown and the muscle(s) I am using fail completely.
    This is physical therapy… albeit… Do-It-Yourself, style.
    This is a focused concentration on every voluntary movement my body makes during this time.
    This is an awakening to the complexity in my body which, in what generally appears to be simple movements, allows numerous structures and pathways to work together creating movement in physical space, what my mind originally pictures in virtual space.
    I may be a bit of a Nerd in this regards!
    Over my lifetime, I have always held a certain fascination regarding my body healing from injury.
    Once I have gotten over the fact that I have been injured, compiled a list of such injuries and attempted to categorize all the consequences derived from them, when I finally feel able or am told to start a physical rehab plan, things get really interesting for me.
    Through a combination of common stretches, certain yoga movements and postures, and physical exercise, I learn about the damage done, I explore my abilities still intact, and I push-and-prod my body in order to regain my range-of-motion, my physical strength, my ability to go back out and push my limits once again.
    That's the physical aspect of it all.
    The mental element is equally fascinating if not more intriguing because I cannot 'feel' the movements of thought in my brain.
    I cannot 'feel' the messages coursing through my nervous system sending commands to muscle, and feedback to brain.
    Now comes the question of, "What is pain?".
    This is a question I have spent a fare amount of time trying to understand.
    Most of my knowledge has been derived from Anatomy & Physiology courses, other scientific readings, as well as anecdotal stories about Monks sitting in snow almost naked yet controlling their body temperature such that the snow about them melts away, and stories of so-called primitive people engaging in body piercing and modifications without the aid of modern medicine and chemistry.
    To date… I have no clear understanding of my own physical pain.
    I have been told by laymen and physicians (to include my Orthopaedic Surgeon) that I have a 'high tolerance' for pain. I take their word for it because I have no way of measuring my tolerance against anyone else's… where is the true gauge of how much pain one should tolerate?
    As I make my arm rotate upward in an arc aligned with the coronal plane of my body (out to the side from thigh up to my ear, basically), I feel the muscles tighten all around my shoulder. As the arm moves ever higher and the muscles tense further, I recognize a particular tension deep within my medial deltoid… or is it beneath? I know that if I push my arm further in that direction this tension will become pain… sharp pain… the kind of pain which shuts down the voluntary movement, perhaps even causing a reaction where I drop the whole shoulder, rotating downward at the hips as if I can move away from the pain like I would dodge a tree along the trail I was riding.
    What I am learning through these exercises in motion, is control.
    I am learning how much voluntary control I have in this area of my body.
    I am learning to control my fear of pain, control my reaction to the signals telling me the pain is here and is growing.
    I am learning to control the movements of my arm and shoulder as these signals flood my brain, and I am able to correct an angle, move a few degrees one direction, relax some muscles while bringing others into play in order to avert the impending pain and loss of control should I not make the correct choices.
    It's a game… a mind game and a physical game, all played out within my body.
    Each day I take the time to put myself through all this, I not only gain more range-of-motion, I gain strength of mind, strength of will over certain adversities that may come in my life.
    …either that… or I just have deep masochistic tendencies!
    EMBA Member
    Reputation: Ladmo's Avatar
    Jan 2013
    I didn't read all of that, but from what little I did read, it sounds like you didn't go to see a doctor? Maybe you should. Certain shoulder injuries left untreated can end up in a chronic condition from which the treatment options are limited. Early diagnosis and proper treatment makes all the difference.
    That is not physical therapy. That is someone who possibly tore their rotator cuff not seeking appropriate care. PT would see you move and send you to an MD for a consult. Pain level does not correlate with injury level. Seek medical help.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Yup.....tried that once....crashed, shoulder hurt and bruised....could move it in certain directions, but not in others....figured I just jambed it. Finally 3 days later when it wasn't getting any better, I finally bit the bullet and went to the doc.......I now have 7 screws and a plate to secure the piece of humerus that was broken.....followed by 5 months of rehab and PT.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    Thanks ya'll, but after a few days I did go see my GP
    Over the last few years I've also had my share of shoulder injuries, even one resulting in torn AC and CC ligs requiring two surgeries.
    I'm taking it slow on the recovery, and really watching how it feels as I go through range of motion exercises.
    If need be, I'll go hit up my Orthopod, He's also one of my mountain biking buddies
    Reputation: ride the biscuit's Avatar
    I agree with the OP, that was incredibly self-indulgent, haha
    I agree with others speculating that you probably tore something important and probably need something more than your own ego and imagination to solve the problem. good luck recovering!
    Quote Originally Posted by ride the biscuit View Post
    You obviously don't know how magical my ego is! lol
    Thanks for the comment.
    I'm still recovering, slowly, X-rays showed no damage, might opt for an MRI soon but still working on it at home and my friend (my Orthopod) told me to do regular PT for a couple of weeks then see where I'm at.
    Honestly… as much as it appears people here took my prose and decided I wasn't being smart about all this… I really have been.
    As far as the story above.. was feeling like a frustrated writer that day and didn't know where to share it… you guys/gals won out!
    I agree that pain is not the only indicator to be used for injury assessment, that's why I've also used ROM, and consulted with the appropriate folks along the way.
    Gotta get in shape for Spring Thaw in Ashland next month! Or else just be a volunteer during the races…
  1. Use Caution
    By crux in forum New Mexico
    Last Post: 05-03-2013, 02:02 PM
  2. Use caution when posting
    By heyyall in forum Off Camber (off topic)
    Last Post: 01-29-2013, 09:25 AM
  3. Shimano HG61 12-36T Caution
    By RideMore56 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-24-2011, 07:52 AM
  4. Caution on Spencer Branch
    By driftwood in forum North & South Carolina
    Last Post: 05-13-2011, 11:53 AM
  5. A word of caution!
    By DaGoat in forum New Mexico
    Last Post: 04-02-2011, 08:42 PM
