Results 1 to 3 of 3
    Monocog 29 -- Chain ring question
    Just picked up an 08 Mono 29 on ebay and so far loving the bike. One thing I noticed is when the chain ring bolts are tight they don't snug down the chain ring completely and there's about 1/16" of play left between the chain ring and the crank. Is this normal for a SS or should the bolts snug down the chain ring completely?
    They must be tightened down, if not they will snap. You can pick up some single speed specific bolts at your LBS or you can use a bashgaurd to fill in the space. I would recommend NOT riding the bike until it's fixed
    Thanks that is what I thought.
