Looking to do a drop bar conversion
ive got a 2010 D600. i would love the ability to ride it long distance gravel types rides, with a bit of single track from time to time.
im thinking about a set of woodchipper bars. love the functionality of them. the problem i forsee is this. What bar end shifters work with the x5 derailluers? Or am i going to be better off swapping out front and rear derailluers and going to shimano drive train
has anyone done anything like this?
There are no SRAM 9-sp barend shifters. If you go with Shimano you will need to avoid mtb 10-sp rear derailleurs. The 9-sp Shimano RDs will work with 8-, 9-, or 10-sp Shimano shifters. barend shifters will likely be the lowest cost, but also look at Sora STI brake/shift levers. They can be less than some barends and brake levers.
mtbtires.com
Here is an alternative to a standard brifter:
[retroshift.com/store/products/cxv
I haven't used it, but it looks interesting. The good part is that it is compatible with mtb disc brakes. The bad... not compatible with SRAM rear der. The front should be fine as it is non-indexed. The company should be able to answer compatibility issues.
so i happened into a redline drop bar with sora brifters and a set of interupter brakes from a cross bike at the local bike coop..........add in a new derauiller, some cables replaced, a few other bits modified........
AND,
i have a drop bar d600...........gonna give abit more of an idea of how it is after a good longer gravel ride tomorrow.......i already am sure i need a shorter stem.....that will come
oh and pics coming tomorrow
- You may not post replies
- You may not edit your posts
Forum Rules
