Results 1 to 3 of 3
    Which carbon fork and bar for my monocog flight?
    I've got this bike set up pretty nice right now with a scandium riser and stock fork. But I'm looking to mellow the harsh a bit so I'm thinking about carbon. Which bar and fork should I look for? I want to keep the correct offset. Thanks, Steve
    I'm using a White Bros Rock Solid fork on my Monocog 29er. It smooths out the ride a bit and improves handling quite a bit. I'm also using Easton EC-70 bars. They do a lot more to smooth the ride than the fork does. I'd recommend both.
    I try to avoid sexual innuendo, but its hard.
    Just Ride
    Reputation: Cormac's Avatar
    I'm torn between upgrading to whiskey, niner or white bros myself...Not sure if I like the blade look of the niner forks. So will most likely go with one of the other 2 when the time comes. Next year at this point.
    SS ==> Nut up or Shut up!
  1. Replies: 9
    Last Post: 05-24-2012, 04:26 PM
  2. Replies: 2
    Last Post: 11-18-2011, 12:48 PM
  3. Monocog 29 vs Monocog 29 Flight sizing
    By MadCowRider in forum Singlespeed
    Last Post: 11-18-2011, 10:25 AM
