Results 1 to 5 of 5
Thread: BB7 issue
    Reputation: kvojr's Avatar
    Apr 2005
    BB7 issue
    Hi all,
    I am installing my BB7's on te stock redline fork but am having an issue. The bottom bolt connecting the caliper to the IS adapter is rubbing on the rotor. Is this a common issue or am I doing something wrong? Do I need a washer in there somewhere? Any help would be greatly appreciated.
    1993 Barracuda A2R - 1x7 Beater
    2007 Redline Monocog 29er
    Yes it is very common just install a washer and you will be all set.
    Apr 2005
    where should I add the washer?
    since you want to have less 'bolt' coming out the backside of the caliper, stick a washer or two between the adapter and the caliper (both bolts). I had the same issue with my brakes when installing them (not BB7s), at least it's an easy fix...
    ride, eat, sleep, repeat
    Apr 2005
    Gotcha, thanks!
