Results 1 to 3 of 3
    09 D660 1x9 to 2x9 ?
    Hi, I have a 2009 D660 and would like to convert it to a 2x9 setup. Could you please help me with a recommendation of Sram parts that would be need for this conversion? I would like to use a bash guard on this setup. Can I use Sram 2x10 crank and front derailleur? Any help would be greatly appreciated.
    Aug 2010
    You can start by taking a look at what Redline is specing on the 2011 D440. They are using a Truvativ E 400 crankset with 28 - 38T gears and a bashguard. They are also using a Shimano FDM 191 Derailleur and SRAM X5 shifters. It might not be the perfect fit for you, but it at least gives you a starting point, and you know that Redline has used this combination successfully on the D440 frame.
    The D660 comes standard with a Stylo 1.1 crankset, you could get the same Stylo, but the 2.2 version. It has all you need, then just get a front derailleur and shifter to match the rear ones.
