Results 1 to 33 of 33
    Ebay Titanium/ predatorbike.com FXB29 29er
    Any word on these? They're selling frames on Ebay for under 700 shipped. Anyone ride one of these?
    here is the link
    http://cgi.ebay.com/titanium-bike-fr...item336281adc8
    for those interested
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Why do they grind and polish the welds ?
    Reputation: Slurry's Avatar
    Dec 2008
    makes crappy welds look better.
    Cannondale
    Guess no one has bought one of these yet?
    Reputation: Phil335's Avatar
    Feb 2010
    They don't look to bad
    Sep 2004
    Went out on their site and the 29er page is up. Vbrake studs...thats got to be one of the few if only new ti 29er production frames I have seen recently that still gives you that option. Also looks like it has a seat stay braze-on for a rack? Weight is pretty good too at 3 lbs and change.
    get down!
    Reputation: appleSSeed's Avatar
    the angles look weird
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Dec 2004
    Quote Originally Posted by appleSSeed
    Which angles look weird?
    Quote Originally Posted by N10S
    I emailed them and said that you can opt to delete the canti bosses if I/you wanted for no extra charge.
    Reputation: 家ndyA's Avatar
    Interesting.... verrrrry interesting. I might also look into getting a disc CX frame...
    Randy
    Not big enough. I need a 63-64cm top tube.
    MTB B'dos
    Reputation: LyNx's Avatar
    Hope
    Exactly! Those are THE BIGGEST and crappiest looking Ti welds I have seen, they look like alu welds, about the same size too, not the sweet, small welds you're accustomed to seeing on quality Ti frames I know for sure I won't be the guinea pig testing if those welds hold up, wonder who will be the first
    Quote Originally Posted by Slurry
    Quote Originally Posted by AZ.MTNS
    Reputation: poppy's Avatar
    I an not an expert but usually Ti frames need to be purged to protect the inside from contamination while the welding take place.
    The pic does not show any of that,
    I hope I'm wrong.
    Reputation: wobbem's Avatar
    The purging is part of the welding process, an inert gas is supplied to the weld the same time the weld is done. The photo is correct.
    Doesn't look right to me. It doesn't look like there is any back purging the insides of the tubes. Only thing that looks to be hooked up to any gas is the tig torch.
    Tulsa
    Reputation: rojogonzo's Avatar
    I don't know about Ti, but for stainless I purge inside as well as the gas supply at the electrode
    wherever you go, there you are
    Quote Originally Posted by AKamp
    Are you a welder? The opinions of the ignorant are meaningless.
    Quote Originally Posted by GTR-33
    I am , the statement that back purging is necessary is 100% correct .
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Double pass welds (what cannondale does) are stronger and more time consuming. But they give you more weld filler and better penetration of the base metal. They also give you something to file down so you get a smooth weld to paint over. I've seen it done with steel frames also.
    I don't post to generate business for myself or make like I'm better than sliced bread
    West Chester, PA
    Why not just get a motobecane with a reba for $1000 ? At least they have some reputation to go by and the cost is similar if you sell the fork. And the dropouts are 100x nicer, among other things.
    So are you trying to say your comment was meaningless
    No, I am not a welder by trade but have taken a couple of TIG classes and lay down pretty decent bead.
    It's just annoying to read so many opinions of the untrained man, which seems to happen here more than anywhere else. So much speculation and very little fact on these forums.
    What is the basis for your complaint? I can weld too and I don't see any evidence that they are missing something from the equipment or that the welds are poor quality other than being larger than what some may say is nessasary.
    Then again... A US made boutique frame is more than five times more expensive. Why would some Taiwanese or Chinese waste time making pretty welds instead of ones that just work?
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Read some of this and you'll see that all sides of a Ti weld must be shielded, which means the inside of the tube has to be purged of oxygen.
    http://www.millerwelds.com/resources...tanium-welding
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Because the oxygen contamination on the backside of the weld will lead to contaminants in the weld. It doesn't just make for a prettier weld, it makes for a stronger weld and it is very important for titanium, less important for stainless and little importance if you are building bumpers for your truck. If I was relying on my headtube to stay on my bike I would like to make sure that there are no impurities in the welds holding it to the down and the headtubes. I could care less if they are single pass or double pass as long as they are structurally sound. If you don't believe me shoot an email to Moots, Potts, IndiFab or any other reputable builder. If you really want to know call up any builder that does much repair work for other builders. Steve Potts has some pics on his blog of crappy welds that held together about as well as JB weld.
    Reputation: boomn's Avatar
    As has already been explained Titanium has different requirements for proper welding ,and one of those is that the weld be completely shielded from normal air using an inert gas, including the root side. The normal way to protect the root side is a gas purge through the frame tube being welded. This is what appears to be missing. A Ti weld done without this will likely look perfectly fine, however it will be a lot more brittle. Some Chinese ti welders have been somewhat popular in the past because they could sell Ti frames and forks so cheap, and then parts started failing because of poor manufacturing like this
    My point is that in the pictures they only piece being actively welded is a cable stop. I don't think it will cause the seat stay to break, it very well could, but this is also a titanium frame at the price of a cheap steel or aluminum frame.
    True, lets hope that back purged everything else. At some point though you can only make stuff so cheap while still maintaining quality and making a profit. Lets hope that this is still above that point.
    Dec 2010
    Reputation: Vecsus's Avatar
    Moving this to the frame builder forum.
    Vecsus
    HTFU or STFU
    Old school BMXer
    Reputation: Blaster1200's Avatar
    Quote Originally Posted by Vecsus
    Because talking about ebay frames is a hot topic here???
    May the air be filled with tires!
    The Brutally Handsome
    Reputation: Sizzler's Avatar
    Quote Originally Posted by rubegoldberg
    Did you register last December to post this reply but on your way fall into a coma and suddenly wake up this morning to finish what you started?
    ack! If anybody bought one I'd like to know their experiences...
