**MODS delete if this is "inappropriate, or move if necessary***
Hello,
I'm new here but I'm not...... I first registered in 2003, and the "system" doesn't even remember my email.(I tried the "Forgot your password" thing, and there is no record of my email being registered here...and yes, it's the same email I used back then)
Not sure if this is the right sub forum for this:
I have a bike that I want to sell, and am trying to figure out what it's worth or what I can expect to get. And if it'd be more worth my time to part it out.
Please let me know where I can find this info. or if this is the place.
I don't expect a full appraisal, but, that would be nice..... I know there is a Classified section, and this is not it. I'm just trying to get a feel for what I can expect... I paid $1400 for it in 2007(did I get ripped?)
Thanks for any help/suggestions... you can PM me if that is more appropriate.
Heres specs to the bike:
2004 SPECIALIZED BIG HIT (Small)
Heres the Stock specs off the Specialized website….(the * =non stock parts)
REAR SHOCK
Manitou Swinger 4-way, SPV position-sensitive damping, externally adjustable pedal platform, progressivness and rebound. 8.75 x 2.75"
*Fox Vanilla RC w. Lizard Skins Boot
FORK
Marzocchi Junior T, 170mm travel, dual crown, coil spring w/ air assist, 20mm thru-axle, integrated stem
*2006? Rockshox Boxxer Race complete with stem and triple clamps
HEADSET
Cr-Mo, 1 1/8" threadless, all alloy and steel construction, loose ball bearing with seals
*FSA, blue anodized
STEM
Marzocchi Integrated stem, 55 to 67mm adjustable, 31.8mm OS bar clamp, 0 degree rise
*Whichever stem came with the Rockshox Boxxer Race
HANDLEBARS
Specialized BigHit rise bar, 6061 butted alloy, 31.8mm clamp, 6 degree upsweep, 9 degree backsweep, 670mm
TAPE / GRIPS
Specialized MTB grip, black, double density Kraton
*ODI Lock on grips
FRONT BRAKE
Hayes HFX-9 full hydraulic disc, 8" rotor
REAR BRAKE
BRAKE LEVERS
FRONT DERAILLEUR
Shimano M-570 LX, E-type, bottom pull
*No front derailleur, has bash ring instead
REAR DERAILLEUR
Shimano M-750 XT, short cage, standard spring
SHIFT LEVERS
Shimano M-570 LX
CASSETTE
Shimano HG-50 LX, 9-speed, 11x34t
CHAIN
Shimano HG-73
CRANKSET
Truvativ Holzfeller 7050, ISIS spline, 7050 alloy, 170mm
*Shimano Saint
CHAINRINGS
32Sx22S, 4 bolt, compact 104/64mm pattern, 5mm thick 7050 alloy bash/rock guard
*not sure
BOTTOM BRACKET
Truvativ ISIS Gigapipe 4 bearing DH, 73mm shell, 118mm spindle, E-Type
*Shimano Saint
PEDALS
Alloy platform, 3mm pressed pins, 9/16" Cr-Mo axle
*ManOwar Platform type
RIMS
Sun Single Track, 26" front, 24" rear, black, eyelets
*REAR- Halo Tornado
FRONT HUB
Specialized Stout disc, 36 hole, cartridge bearings, 20mm alloy thru-axle
REAR HUB
Shimano M-525 disc, 36 hole, sealed loose ball bearings, alloy Q/R
*Halo
SPOKES
DT Swiss, 2.0mm (14g) stainless, black, brass nipples, L258/R260mm front,
L233/R231mm rear
FRONT TIRE
Specialized Roller RS 26 x 2.3" medium compound, aramid bead, Cap Ply reinforced casing
*Duro DH Shore designed by .234 Racing- 26x2.6
REAR TIRE
Specialized Roller RS 24 x 2.3" medium compound, aramid bead, Cap Ply reinforced casing
*Duro DH Shore designed by .243 Racing- 24x2.6
TUBES
Specialized 24" (R) / 26" (F) x 2.4/2.75", schraeder valve
SADDLE
Specialized BigHit, 8mm Cr-Mo rails, X-Brace
*Azonic Downhill seat
SEAT POST
Alloy, black, 30.9 x 300mm for 8mm rails
SEAT BINDER
Alloy collar with Q/R, 34.9mm clamp I.D., black
NOTES:
Theres nail polish on probably every screw or nut…. I put it there so I can visually check if the bolts/nuts are backing out.(old dirtbike trick).
The rear tire is starting to dry rot. Still good.
Small Frame
