Results 1 to 34 of 34
    Zigzag's Mach 6 build from France and new cable routing
    Hi
    This is my new bike after Stumjumper Elite 26"... I'm living in south of France.
    ______________________________________
    Last configuration:
    - Can creek XV air volume
    - Renthal Stem
    - Zee brake whith Uberbike pad RACE MATRIX
    - Race Face Turbine whith narrow 30T
    Zigzag's Mach 6 build from France and new cable routing-pivot-zigzag-effet1.jpg
    Zigzag's Mach 6 build from France and new cable routing-pivot-zigzag-pola1.jpg
    I'm wainting Integra KS...
    My cable routing it's a little différent than Vikb's solution
    I used Jagwire stick-On_Guides (Jag
    Zigzag's Mach 6 build from France and new cable routing-routing-cable-cadre.jpg
    Zigzag's Mach 6 build from France and new cable routing-detail-support-2.jpg
    bad reputation
    Reputation: turfnsurf's Avatar
    Nov 2007
    Nice ride, you chose the continuous cable housing option! Curious to hear how you like the CCDB shock...have you tried the stock Fox Float X for a side by side comparison?
    Aug 2010
    Interesting way to route the cables and doesn't look half bad. Curious as well to see how that CCDB is on the M6….thought about getting the Inline CC.
    Reputation: wilks's Avatar
    Tres bien
    Quote Originally Posted by turfnsurf View Post
    I don't compare this two shocks, beaucause i bought the M6 whith the CCDB
    New black Jagwire support
    Mudguard Homemade
    Reputation: vikb's Avatar
    Nicely done.
    I'll be going full housing on the derailleur as well sometime before winter hits the PNW.
    I'm digging the external cables. Easy to install/maintain and zero hassle when riding. I hopeful the bike industry re-invents external cables as a huge "new and improved" feature.
    Safe riding,
    Vik
    www.vikapproved.com
    Zigzag's Mach 6 build from France and new cable routing-la-roques-22_06_14.jpg
    Zigzag's Mach 6 build from France and new cable routing-la-roques-pierrier-22_06_14.jpg
    My new CCDB setting (Pivot information)
    Pour le CCDB: 30℅ de SAG.
    HSC: +1
    LSC: +3
    HSR: +1 1/4
    LSR: +8
    Best setting for me !!!
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Cable routing....
    The M6's cable routing is very finicky, but if done "just right" it works out to be one of the best I've encountered.
    You've just got to work on the placement of the housing and cut it to the precise length.
    I think too many folks have given up on pursuing the correct routing method too quickly - I almost did.
    Oct 2011
    The Pivot routing does work if done perfectly...and it better be perfect. When it is time for cable replacement I am going to try the routing used by the guy from France. That looks like the easiest and best solution yet.
    Oct 2011
    Quote Originally Posted by zigzag84 View Post
    HSC: +1
    LSC: +3
    HSR: +1 1/4
    LSR: +8
    I am not wanting to try the CCDB. Not to thrilled with the Float X. How much do you weigh and what kind of terrain are you riding?
    Quote Originally Posted by endoguru View Post
    It's me "the guy from France" ! Bertrand
    The Pivot M6 whith CCDB is amazing !!!
    New routing support frame:
    Before:
    Zigzag's Mach 6 build from France and new cable routing-ancienne-tenue-gaines.jpg
    Now: (specialized support cutting)
    Zigzag's Mach 6 build from France and new cable routing-support-cable-stumpjumper.jpg
    Oct 2011
    [QUOTE=zigzag84;11410286]It's me "the guy from France" ! Bertrand
    Thanks for the reply Bertrand. "The guy from France" sounded pretty lame didn't it? There was no insult intended.
    I really like your solution to the cable routing. It is the best solution I have seen to the one mistake Pivot has made on this bike. Other than that I love this bike and can't wait to try the CCDB shock.
    Just out of curiosity, being from France, have you tried the BOS Kirk shock? I am reading such good things about it. I am trying to decide between the BOS and the CCDB. The BOS has just become available in the US.
    [QUOTE=endoguru;11410692]
    No problem ! It s a joke
    Thank you for my routing ... Inspiration Virk
    I haven t try the kirk...
    Vid testing kirk : http://www.zapiks.fr/test-kirk.html
    I think is a excellent shock also...
    Mar 2011
    Hi - Where does one find the little plugs used to cover up the internal frame ports? Thanks! It really is a shame it's not beneficial to use the internal routing
    Quote Originally Posted by umicheng View Post
    This one ?
    This is a rubber o'ring
    This one ?
Name:	support cable stumpjumper.jpg
    Good idea thanks. I'm not using the internal cable routing on for shifting or brakes.
    Safe riding,
    Vik
    www.vikapproved.com
    Hello...
    New color stickers for my Bos Deville.
    Zigzag's Mach 6 build from France and new cable routing-bos-stickers-green-lime.jpg
    This is my new brake : Zee Shimano
    Oneup RAD cage and Oneup 42T
    Zigzag's Mach 6 build from France and new cable routing-d%E9railleur-zee-rad.jpg
    I don't understand why people dislike the cable routing on the M6. I agree it is a bit of a pain to install but after that it is awesome. The routing is clean, quite and hassle free. I'm perfectly happy with it and would never consider sticking any adhesive cable mounts to my beautiful frame. Just my opinion.
    Quote Originally Posted by aevanlloyd View Post
    I've found it anything, but clean and hassle free on our 2 M6's.
    I've switched my bike to external cable guides already and will do the same for the GF's bike next over haul.
    The extra few inches of exposed cable housing on my bike is totally a non-issue and servicing cables is now super easy.
    I'm also going to drill out the rear derailleur guide and run full length cable housing on our bikes. We live in the PNW so that last 12" of exposed cable is right where the rear wheel dumps water and grit.
    Safe riding,
    Vik
    www.vikapproved.com
    bad reputation
    Nov 2007
    My derailleur housing broke during a race. The protective shell wore off and the inner wire core exploded! Not the cable, the HOUSING - from rubbing against the brake hose & the shock over a period of about 5 months. I've since switched to stick-on cable guides for the derailleur & I'm waiting to do the brake, which is a pain because I'll need a new hose, fluid & bleed. The stock M6 routing causes wear & tear to the cables, cable rub on the shock, & yes it works for a while, it can fail when you least expect :-(
    Quote Originally Posted by vikb View Post
    And maybe that is the difference. I live in the desert and after nearly a year on the bike have not had one issue with the cables. But I rarely ride in the mud.
    In Search of Singletrack
    Reputation: shosan's Avatar
    you also have to remove the entire rear shock in order to access/thread cables thru the frame. what a pain! good luck doing that on the trail.
    Zigzag's Mach 6 build from France and new cable routing-10257104_1013747015308177_6637207305890596318_o.jpg
    - potence Renthal 50mm
    - Freins Zee
    - Plaquettes Uberbike RACE MATRIX
    - Race Face Turbine
    - Race Face Narrow 30T
    - Stickers Bos Green Lime (bkstickers.com)
    Feb 2012
Name:	detail support 2.jpg
    where did you find these Jagwire guides? I can't find anywhere and looks like a good idea. can you give name or where you bought?
    or did you just drill a hole into the stick on guide?
    Quote Originally Posted by TheBicycleHater View Post
    or did you just drill a hole into the stick on guide?[/QUOTE]
    Jagwire stick-on_guides
    Stick-On Guides | Jagwire
    Mudguard Homemade
    Hey Zigzag mind sharing a template for your homemade rear mudguard?
    Reputation: SDMTB'er's Avatar
    Feb 2014
    Nice video! The gauges for speed elevation and grade are really cool!
    Quote Originally Posted by SDMTB'er View Post
    Thank you
    The Cam is Garmin Virb Elite whith GPS
  1. Mach 5 derailleur cable routing
    By Dirtrider127 in forum Pivot Cycles
    Last Post: 02-16-2013, 10:07 PM
  2. 2011 Mach 5.7 cable routing
    By Donalwho in forum Pivot Cycles
    Last Post: 10-03-2012, 11:53 PM
  3. Pivot Mach 5.7c cable routing?
    By agg25 in forum Pivot Cycles
    Last Post: 04-30-2012, 08:01 AM
  4. Help: Mach 5.7 Rear Swingarm Cable Routing Issues
    By Rei_Ikari in forum Pivot Cycles
    Last Post: 11-23-2011, 07:01 PM
  5. Mach 5 cable routing?
    By joshdurston in forum Pivot Cycles
    Last Post: 04-01-2011, 09:50 AM
