Results 1 to 22 of 22
    Reputation: edbraunbeck's Avatar
    Where are Pivot pictures from Eurobike?
    Please post the links:
    pictures and news please!
    Pd: Pivot Firebird will finally have a rear axel of 12x135mm????
    Few pics available at Singletrack: http://www.singletrackworld.com/2010...ott-and-pivot/
    Does anyone have any information about the availability of Mach 5.7?
    Fat & Single
    Reputation: ozzybmx's Avatar
    So does the new 2011 429 not have a tapered headtube too ?
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    No changes to the 429. The frame kit and complete bike are shipping with a taper ST fork and a taper adaptor headset cup. The M4 & M 5.7 have the taper steer tube.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Paterfamilias
    Feb 2006
    Mach 5.7 will be available late September.
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Reputation: toHELLuRIDE's Avatar
    When is the firebird due for some fine tuning?
    More travel. slacker headtube.
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    is the Mach 5.7 the Mach 5 replacement or will it be a heavier duty Mach 5?
    i need to develop my crashing skills...
    Pivotal figure
    Jan 2003
    The 5.7 is in fact replacing the 5. As for the Firebird, no plans to make changes to that bike. The Phoenix has a slacker HT and more travel though...
    Quote Originally Posted by kenbentit
    Too bad....that's the kind of bike that begs for some adjustability.....
    Quote Originally Posted by toHELLuRIDE
    Oh and a steeper seat tube angle. It's time for a refresh. Cmon 180mm travel, 65.5 ht angle, and a 73 degree seat tube angle. I agree the rest works just fine.
    Chillin the Most
    Quote Originally Posted by dog
    Your asking the same question, just in different context???
    Either way, replacement!
    Chillin the Most
    Quote Originally Posted by Mrwhlr
    I agree, let see...
    maxle rear axle or some kind of thru axle option , maybe interchangble dropouts
    lower BB (which shouldnt be an issue with DW Link)
    Slacker angles @ 66.5-66.7
    Coil shock option
    thats all for now, Im sure more will come to mind
    Pivotal figure
    Jan 2003
    Angleset on the Firebird is a great option if you want to adjust the HA a bit. I'd be trying one out if I didn't already have the 180 TALAS on mine.
    Reputation: crank1979's Avatar
    Feb 2006
    Quote Originally Posted by RED5
    Coil shock option
    I don't think the Firebird needs the thru axle rear end for stiffness, but for keeping up with some other companies marketing it might.
    I like the current bb height and HA!
    Mine works brilliantly with a CCDB on it.
    Reputation: ruralbike's Avatar
    Mar 2006
    Ive only founded this one.........
    Attached Thumbnails Attached Thumbnails Where are Pivot pictures from Eurobike?-noname-4.jpg
    Chillin the Most
    Quote Originally Posted by crank1979@optusnet.com.au
    So what do you weigh @ 160lbs soaking wet with a brick in yer pocket?? Believe me when I say anyone over 200lbs appreciates a thru axle on any bike built for real riding, which the FB is def one of those bikes (with some tweaking).
    Personally after seeing the geo #'s for the Phoenix Im sort of leaning that way for my do all bike. Toss a Van 36 180 on front, Ti Spring, 5" Gravity dropper and light/burly wheelset and its good for all day riding.
    Feb 2006
    I'm about 85kg with all my gear on. I noticed the rear felt stiffer than my Gen 1 Nomad straight away.
    Chillin the Most
    Ok so you weigh 187lbs +/-, I was close!
    Yeah but a lot of people complained about the flex on the G1 Nomads. Anyhow just saying it would be a definite improvement and would affect you light weights adversly but def benefit us clydes.
    Reputation: gticlay's Avatar
    I disagree. The F-bird is super stiff. It's not like the bikes with pivots IN the rear triangle - the triangle is all welded up. I wouldn't hurt to have interchangeable dropouts because then you could make ones to lengthen the wheelbase a little or do a maxle or something but the QR dropouts are fine, IMO.
    I just put an order in for a Float 36 180 for my bird
    "It looks flexy"
    Feb 2006
    Lol! I wasn't one of those complaining about the Nomad. I loved that bike. I don't see how a stiffer rear end would adversely affect the ride for lighter riders, just run bigger tyres!
    POLAND (Europe)
    Reputation: Pawel's Avatar
    Here's some of our photos from Euro Bike, enjoy :-)
    http://picasaweb.google.pl/kopecprzemek5/Eurobike2010#
