Page 3 of 5 FirstFirst 12345 LastLast
Results 201 to 300 of 444
  1. #201
    Reputation: joezuri's Avatar
    Mar 2011
    Quote Originally Posted by 40er View Post
    joezuri, good stuff...I just stop all business today so I can get this moving. How did you set up your rear derailleur to click for all 11 cogs?
    It's still a 10speed. You need to tune it as usual, only adjust the b tension for correct jockey wheel spacing to the cog. Shifting have been flawlessso far. I do not eeven have to change to a longer b tension screw. Using a Sram medium cage x9 rear d
  2. #202
    Dec 2011
    Thanks joezuri. I finally got to the instructions at thenwebsite.
    I got way too excited thinking of 1x11 without spending $1000. Still a very good option. Twice a year I go to a series of trails that have some serious climbing, and although I'm very happy with my 1x10 w a 36t on the back. I have to make a quick conversion to a 2x crank that I have for that place only. Long brutal climbs. However, with this I can go ahead and buy and install the chain ring, which as I understand has the similar tooth profile of the xx1 assuming no chain drop, and install the 42t on the back when I go to the mountains. Well who knows i may just leave it.
    Thanks again
  3. #203
    Feb 2014
    I swapped out a reba for a fox both 120 the fox seems to have better small bump compliance and now I can run the tires that rubbed on the reba. Didn't know when I got it they olny handle 2.25ish tires. Resealed my shock way easy.
  4. #204
    Dec 2011
    I have heard from many people that the Roxshock advantage was the small bump compliance, perhaps not specifically the Reba. I know I had a Reba, on another bike and could never get it dialed riight. FOX RLC all you need to do is put air and be done.
    Just curious what Model Pivot you have?
  5. #205
    Feb 2014
    Mach 4
  6. #206
    Wolftooth
  7. #207
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    HAAA, I used that same setup with my X0 crank and WT ring ^^^^^^ on my Carbine 29.
    I just added the 42t OneUp to my 1x10 drive train on my LES. Very simple and easy to set up. Works well and I didn't have to change chain length. I would have gone with the WTC 42t or Hope 40t, but bought this for the introductory price when it first came out. I now have little more long steep climbing ability with my 34t/ 11-42 drivetrain.
    Attached Thumbnails Attached Thumbnails What have you done to your Pivot Cycle lately?-img_5379.jpg
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
  8. #208
    Big Test Icycles
    Reputation: Hangtime's Avatar
    Wolf Tooth 42t GC added to the 1x set up on my FB. Maiden voyage today at Black Rock, Or. Easy installation and it shifts perfectly. The 30t up front is perfect for the 3mile climb to the top. I'm continually blown away at just how versatile the FB is. Mine started out as a 35lb light DH set up and now sits at 30lbs for more Endure riding and racing. The 1x set up is perfect for the Bird.
  9. #209
    Reputation: SDMTB'er's Avatar
    Feb 2014
    What have you done to your Pivot Cycle lately?-imageuploadedbytapatalk1396794115.332284.jpg
    Ergon GS1 grips
    Hans Dampf front, Racing Ralph Back tubeless
    Garmin Edge 805 gps
    KS Lev Seat Dropper post
    Adamo Peak saddle (highly recommended - this is the way bike saddles should be)
    Bike currently weighs 26 lbs.
    Have Light Bicycle rims on order - will build wheel set with DTSWISS 240 hubs.
    Rider: 215 lbs, 6 feet
    Frame size: Medium
    Tire pressure: 25 f / 30 b
    Shock settings: Front 90 psi @ 8 clicks; Back 180 psi @ 9 clicks.
    Ride mostly: East and North county San Diego trails (XC / trail)
  10. #210
    Binned
    Nov 2008
    ^ Nice! What rims are you using for the wheel set being built?
    I had my '09 alloy Mach 429 down to 25.76 lbs with Stans Crest wheels and S-Works tires at one time but I have since beefed it up for riding in AZ (I'm from So Cal) since I go there fairly often these days. It now weighs nearly 27.5 lbs with Stans Arch EXs, beefier Spesh tires, beefier stem and handlebars.
  11. #211
    650b me
    Reputation: golden boy's Avatar
    Noticed a new creak while riding my '09 Mach 4 the last 2 days. Like most people, I like a quiet bike. I'm taking a methodical approach to eliminating the creak. Tonight I disassembled the saddle clamp on my Easton EC70 seatpost, wiped everything down, greased the bolts and put it back together. Did the same for the seatpost clamp. Lastly, put a thin film of carbon paste on the post itself.
    Exciting? No...but it's what you do when you love and cherish a bike, and I do!
  12. #212
    Feb 2014
    Quote Originally Posted by Hawg View Post
    I am having the Light Bicycle (that is the name of the company - massive thread on this forum for their solution to affordable carbon rims) hookless 29'er AM rims built. Changed my mind and am going with 350 hubs - cost of 240s not worth the marginal weight savings). Rims have been shipped and should arrive any day.
    Also considering changing stem (currently 100mm FSA) out to an Answer Rove 70 mm and swapping the FSA 740 mm stock bars for Answer pro taper 720mm. The 740s just feel too wide for me as my arms feel too far from my body.
    My biggest complaint about the Pivot is for me in technical turning sections the bike feels a tad squirrely and I also feel to far forward over the front axle. Hoping that shorter stem will but me behind the front axle more and the narrow bars will also push me back a bit from the headset.
  13. #213
    Reputation: broccoli rob's Avatar
    Race face next cranks
    point one podium 2 pedals
    new xt shifter
    xt cassette
    40t wolftooth GC (shifts clean, dropped the 11t)
    Weighs a little under 33lbs
  14. #214
    Aug 2013
    Put on a new rear rim, trued and taped it, and installed some high roller II's. Sealed up with stans and the new tires worked awesome in Sedona last weekend!
    Pivot Mach 5.7 Carbon XT/XTR Pro build
    Fox 34 Talas CTD Fork, Lev dropper, SPDs
  15. #215
    Proud Thunderchicken ownr
    Reputation: btibben's Avatar
    Re-threaded the rocker bolts on the Firebird
    One side fully stripped out.
    Fully disassembled frame, strapped it into a lathe, leveled from every possible angle, drilled clean through on both sides, tapped, heli-coiled.
    Finger's crossed.
    Common sense is not so common - Voltaire
    Never underestimate your own ignorance - Me
  16. #216
    Reputation: MSU Alum's Avatar
    Put on Easton carbon Haven wheels, converted to 1x11 with a Next SL crankset. Added a DOSS dropper post.
  17. #217
    Feb 2014
    Added Light Bicycle rims and replaced stock FSA 90mm stem with 70mm stem.What have you done to your Pivot Cycle lately?-imageuploadedbytapatalk1399386978.845831.jpgWhat have you done to your Pivot Cycle lately?-imageuploadedbytapatalk1399386989.830077.jpgWhat have you done to your Pivot Cycle lately?-imageuploadedbytapatalk1399387000.481234.jpg
  18. #218
    Just Joshin' ya!
    Reputation: PrincipalRider's Avatar
    Jun 2005
    Quote Originally Posted by Hangtime View Post
    HT, did you remove the the floating thing that carries the front derailleur and that spring? I am doing the same conversation to my FB this week and I have been wondering about that.
    Getting a dropper post is like getting a bidet. I didn't know I needed one until I get one and boy, does my ass thank me.
  19. #219
    Dec 2011
    Broke my xt derailer again! This time it ate the cassette and chain.
    So now I have a saint shadow shorty with x10ti chain and a 34xt cass
  20. #220
    Reputation: Sketchemo's Avatar
    Gave it a bath and put a new Pike on!
  21. #221
    Dec 2011
    ^^^ how's the pike!
    When my fox craps out again going for a pike!
  22. #222
    Quote Originally Posted by WarBoom View Post
    ^^^ how's the pike!
    Just had a quick run on it but it seems like a big upgrade from the Fox 32 Float RL that I had. The biggest difference I noticed is that I don't have to muscle the front end around, really looking forward to getting it dialed in tomorow
  23. #223
    74 & 29 pilot
    Oct 2010
    Finally got the chance to really test out the the 1x10 34t/11-42 with the one-up 42t ring and finally put some carbon wheels(Havens from 429) on her. I was using the DT Swiss XR1501s that came with my 429c, but my 200lbs azz and a super stiff rear on the LES was leaving tire marks on the inside of the chain stays. Little heavier, but but solid and make the bike ride better. The 11-42 cassette set-up works great and gives me plenty of granny for longer climbs!!
    MTBP
  24. #224
    Reputation: seandm's Avatar
    that's at the top of Brown's looking south right?
    Sent from my SCH-I535 using Tapatalk
  25. #225
    74 & 29 pilot
    Oct 2010
    Quote Originally Posted by seandm View Post
    Yes sir.
    MTBP
  26. #226
    Long Live the Gorn!
    Reputation: bvader's Avatar
    Quote Originally Posted by SDMTB'er View Post
    Added Light Bicycle rims and replaced stock FSA 90mm stem with 70mm stem.Click image for larger version.
ID:	891233Click image for larger version.
ID:	891234Click image for larger version.
    How you liking the rims so far... and issues?
  27. #227
    Binned
    Nov 2008
    I recently mounted my skinny wheel set back on for local fire road rides since that is all I've had time for lately. I had to mount a set of new Storm SL rotors to that wheel set before it was ready to go, as well as adding some new juice inside the tires since they'd been sitting around for quite a spell.
    The heavies are going back on for the upcoming trail ride this weekend, though.
    Some time this Summer I will be rebuilding my drive train. New XTR M970 (11-34) cassette, new KMC SL9X chain, New 26 & 38 tooth XTR chain rings, new cables & housings, and a new XTR M972 Shadow RD. I'm looking for a brand new XTR M970 right shifter but they are all but extinct now.
  28. #228
    RaceFace Next cranks added yesterday. Weight is at 27.6lbs
    What have you done to your Pivot Cycle lately?-wp_20140530_18_21_19_pro%5B1%5D.jpg
    Don't aim for success if you want it; just do what you love and believe in, and it will come naturally.
  29. #229
    Binned
    Nov 2008
    UPDATE:
    I couldn't stand the instability of the skinnies on dirt so I put the trail tire/rim combo back on, lol!
    It would appear that I have become accustomed to the feel of pushing the bike harder with wider more aggressively treaded tires.
  30. #230
    Reputation: vikb's Avatar
    +1 - I have the same problem. My solution was a lightweight wider wheelset with wider tires that were on the lighter end of the spectrum. That way I don't give up much either way.
    Safe riding,
    Vik
    www.vikapproved.com
  31. #231
    Quote Originally Posted by speedraceratl View Post
    Man those look good
  32. #232
    Jul 2013
    Fresh Legs
    Nox Composite AM 29 Wheels with I9 Torch Classic Hubs. Wide, stiff, and fast engagement.What have you done to your Pivot Cycle lately?-429c-014.jpgWhat have you done to your Pivot Cycle lately?-wheels-177.jpg
  33. #233
    74 & 29 pilot
    Oct 2010
    I finally converted the 429 to a 1x drive train with Wolftooth 42t cassette cog and 32t ring. After riding my LES and Carbine 29 as 1x, I just got sick of listening to the noise of the 2x and beside I rarely use the 26t ring in front. NO MORE FDs for me!!! Took almost a pound off the bike, now sitting at 27lbs 13oz!
    MTBP
  34. #234
    Binned
    Nov 2008
    ^How much clearance is there between the chain stay and the chain ring? Looks real close.
  35. #235
    74 & 29 pilot
    Oct 2010
    There is plenty of clearance, even for a 34t ring.
    MTBP
  36. #236
    Binned
    Nov 2008
    Yes, I see now. Lots of clearance.
    Did you simply attach the chain ring to the big ring position on the crank? Or is there some sort of spacer used? How's the chain line when on the low gear (big/big) of the cassette?
    I'm asking because I have the same crank set (set up 2 ring) and the chain line is terrible when I'm in the big ring on the crank and on cassette.
    My frame is an '09 Mach 429.
  37. #237
    74 & 29 pilot
    Oct 2010
    Yeah, used the same bolts and attached to the 104BCD(big ring) part of the crank. The chain line is great, pretty neutral until the 11t and 42t; Even then it's not bad and will only be used a small percent of the time.
    Well the 429 and 429c are quite different, so I don't know how well it would work on your bike. That seems odd that the chain line is so bad on a 2x specific crank. On my LES, I had a 3x XTR crank that I used for my 1x set up with a Wolftooth 34t ring. I mounted the ring on the inside of the big ring positions and had to use spacers between the crank and ring due to the chain line being pretty bad. All good now though.
    MTBP
  38. #238
    Binned
    Nov 2008
    Quote Originally Posted by MTB Pilot View Post
    If I were to use spacers to position a single ring (mounted in the 104BCD position) in between where the two chain rings are now, the chain line would be good. I am just a bit concerned about how close the single ring would be to the chain stay. As it is now, the 26 tooth small ring on my 2X crank is pretty darn close to the chain stay. A 32 tooth ring is exactly what I would want to use if I were to go in that direction.
    EDIT: Ooops! It's the big ring (38 tooth) that is uber close to the chain stay, so a 32 tooth would easily work in that position even if I used some spacers to bring it in a wee bit closer to the frame for a mid positioned chain line.
  39. #239
    I swapped out my Fox Float 120mm for a Rock Shox SID XX 100MM today. I have come to the conclusion that for the Michigan woods the 100mm is a better fit for me. The 120 feels floppy. The 100mm is nice and XC fast. Handling has improved and I dropped 7oz.
    She weighs in at 24 lbs 2 oz. There is nothing weak or flimsy on this build. It's pretty burly for 24 lbs.
  40. #240
    SRAM rep came by and outfitted me with some new Guide brakes. So far these things are SICK!!!!!What have you done to your Pivot Cycle lately?-wp_20140614_15_31_16_pro%5B1%5D.jpg
  41. #241
    Reputation: venom550pm's Avatar
    Sep 2012
    Upgraded hubs to Hadley! Love my new hubs!
    2013 Pivot Mach 5.7 Custom Build
    2014 Salsa Mukluk 2 Custom Build
    2014 Foes FXR275 Custom Build in process....
  42. #242
    Apr 2005
    I replaced a derailleur.
  43. #243
    Binned
    Nov 2008
    ^ Ohhh, that looks bad! Were you able to salvage the chain?
  44. #244
    Apr 2005
    Nope. Replaced that too.
  45. #245
    Binned
    Nov 2008
    Quote Originally Posted by swinkey View Post
    Did you hit something to cause that damage?
  46. #246
    Apr 2005
    Climb. Shift. BOOM!
    Wide open trail. Definitely didn't hit anything.
  47. #247
    Binned
    Nov 2008
    Climb. Shift. BOOM!
    Yes, I can see how that could happen although that doesn't make it OK. Whenever I shift while the drive train is under pressure (climbing), I back off for a micro-second. It tends to smooth things out and take the stress off the drive train during a shift in this situation.
  48. #248
    Dual Squishy...
    Reputation: Jeepnut22's Avatar
    Latest thing I have done was to build it up and ride it!!
    5.7c, Medium
    Fox CTD Kashima
    Pike RCT3 Solo Air 150mm
    XO Cranks
    Wolftooth direct mount 32T Chain Ring
    Time ATAC Carbon pedals
    XO Type 2 Medium RD
    XO Shifter
    1070 cassette with the 11T removed and a Wolftooth 42T installed
    KMC Chain
    Thomson 90mm stem (Plan to swap out for a 70mm)
    ENVE Bars
    ESI Grips
    XTR Trail Brakes, 180/160 f/r
    Specialized Command Post Black Lite (Thomson Masterpiece pictured)
    Specialized Phenom SL Saddle
    I9 Torch Wheelset, 15mm front, 142x12 rear
    Trail King 2.4 tubeless up front
    Purgatory 2.35 tubeless out back
    Bar Fly 2 mount for Garmin
    27.00 lbs. exact (weighed with Command Post)
    I love this bike!! I'll get better pics soon...
    What have you done to your Pivot Cycle lately?-image.jpgWhat have you done to your Pivot Cycle lately?-image-1-.jpg
  49. #249
    I rode my Mach 6. After being off the bike for nearly 8 weeks with a broken arm, I call that quite an accomplishment.
  50. #250
    Binned
    Nov 2008
    Quote Originally Posted by aevanlloyd View Post
    Glad to hear it!
  51. #251
    SRAM rep came by and outfitted me with some new Guide brakes. So far these things are SICK!!!!!Click image for larger version.
    What brakes were you riding before? Any more detail?
  52. #252
    Quote Originally Posted by Salespunk View Post
    X0 Trails.
    Details: great modulation, good lever feel and feedback, no noise, a breeze to setup. Thats it for now until I get more rides on them.
  53. #253
    Switched the small chain ring on my 2x10 to a 22t from 24. Made the 429c a much better technical climber for steep, sustained sections.
    Had to repalace the WTB seat, it was creaking like mad. New one isn't any better. LBS said they'd seen a few of those.
  54. #254
    Reputation: ryguy79's Avatar
    What I did lately to my Pivot was that I put it together. New Pivot owner, but not new to DW Link. Started with a used Firebird frame and some parts from my old IH 7 Point 3. Reused the Avid Code brakes, cassette, stem, bars, and RS Lyrik. New parts included Race Face Chester cranks and 30t narrow wide chainring, Sun Ringle Charger Pro wheelset, seat, and post. Hoping to get a dropper post eventually to finish it out. So far really happy with it. Rides a lot like the 7 Point 3 did but its so much lighter. Love it.
  55. #255
    Aug 2010
    swapped out the Answer bar and stem for the new Race Face 35x35mm bars and Atlas 35mm stem. Feels way better.
  56. #256
    May 2005
    1X10 on the M5.7
    1X10 conversion.
    North Shore Billet spider 104 BCD
    Race race Narrow wide 32t
    Fox fox rebuilt S4 suspension.
    What have you done to your Pivot Cycle lately?-spi2.jpgWhat have you done to your Pivot Cycle lately?-spi1.jpg
  57. #257
    Aug 2010
    Installed the biggest volume spacer in the Float X on the left….it comes with the medium one installed….but they should send out a spacer kit with any frame or bike purchase…just like the direct mount cover..hmm!!!
    When riding, I felt it blew through the last part of travel way too fast without that "bottomless" feeling I felt on my other bikes…this may be why some people are striking their pedals more on some chunkier tech stuff…for me..that was an issue
    If this works great..if not..either Avalanche or go for the CC DB Inline.
    Took it on various trails..works great…went down 10psi in the X and it feels waaay better. Definitely worth it.
  58. #258
    Freed myself of a lot of noise on my Les 29.
  59. #259
    74 & 29 pilot
    Oct 2010
    HAAA! I just did the same with my Les. Now that I have a 29+ HT, the Les is going to pull SS duty. I'm using 34t/20t and with dropper post it comes in a 22lbs. Looking forward to it, as this is my first real SS Mt. bike
    MTBP
  60. #260
    HAAA! I just did the same with my Les. Now that I have a 29+ HT, the Les is going to pull SS duty. I'm using 34t/20t and with dropper post it comes in a 22lbs. Looking forward to it, as this is my first real SS Mt. bike:thumbsup
    Have you gone up the side of the mcdowells yet with that thunderburt on there? I found that tire gives zero traction on the climbs, but super fast out at pemb and browns ranch.
  61. #261
    74 & 29 pilot
    Oct 2010
    No, I bought the tire, on the cheap, a while back just to check it out. It's got snake skin, so if it lasts and is descent, I'll use this set up for the tame stuff and another set of wheels that have 2.2/2.3 Bonti's on it for the chunkier stuff like PMP, McD's. I'm not to sure I can go up the side of McD's on a SS yet... Hopefully one of these days.
    MTBP
  62. #262
    Dec 2011
    I washed it today!
    And found a crack!
    Been hearing a pop/creak noise while pedaling and it looks like I've found it
    Its on the milled section of frame behind the sprocket.
    Goes 3/4 of the way thru the piece
    What have you done to your Pivot Cycle lately?-f54db518-a79a-4103-9519-b93c3f7e2710.jpg
  63. #263
    Binned
    Nov 2008
    ^Brutal!!! Is there any warranty coverage in this case?
  64. #264
    May 2005
    5.7 ??
  65. #265
    Dec 2011
    Its a 2013 5.7
    And there better be warranty coverage!
  66. #266
    Dec 2010
    DB inline for my Mach 6.
  67. #267
    Apr 2005
    Got a Pike. So much better than Fox.
  68. #268
    Dec 2010
    Agreed! and bumping up to 160mm even more better!!!
  69. #269
    74 & 29 pilot
    Oct 2010
    I washed it today!
    And found a crack!
    NOT saying it was or you did, but man it looks like someone tried to cut the frame! I've never seen a crack that perfect on aluminum before.
    You don't have an ex girl friend that wants you dead, do ya?
    Good Luck, but no need cause Pivot will take care of you.
    MTBP
  70. #270
    Dec 2011
    New frame complete is on the way don't even have to send in my old rear triangle.
  71. #271
    Binned
    Nov 2008
    EXCELLENT news!!!
  72. #272
    Dec 2011
    EXCELLENT news!!!
    Ya, I really didn't have any doubts. Its just one of those freak things I bet.
  73. #273
    Dec 2011
    Id be more worried about my wife if she found out about my girlfriend!
  74. #274
    Is your old rear triangle a thru axle? If so, you mind parting with it?
  75. #275
    Dec 2011
    Quote Originally Posted by the-one1 View Post
    pm'd u back
  76. #276
    Reputation: XRaptor's Avatar
    Mar 2011
    1x10 setup about 6 months ago & recently found some gently used I9's all internals are in perfect condition.
    What have you done to your Pivot Cycle lately?-imag0604.jpgWhat have you done to your Pivot Cycle lately?-imag0605.jpgWhat have you done to your Pivot Cycle lately?-imag0603.jpg
  77. #277
    Recent upgrades:
    1) RS Reverb
    2) 1x10 with Wolf Components
    3) XO Trail brakes
    4) Tompson 50mm stem
    5) Staightline AMP pedals
    Voilà! Couldn't imagine running a 2x drivetrain anymore!
  78. #278
    Binned
    Nov 2008
    I almost for got to post about my drive train. I replaced most of it about a month ago:
    *new 26 & 38 tooth XTR chain rings
    *new KMC X10SL chain
    *new XTR 11-34 cassette
    *new XTR GS RD
    *new shifter cables and housings
    My FD is working fine so it remains.
  79. #279
    Reputation: ravewoofer's Avatar
    Dec 2008
    I replaced the XTR Shadow Clutch job rear der. after roosting a big rock off the front tire. Smack! Right into the rear der. cage, messing up the lower pulley and aluminum carrier for both pullies. I wasn't happy, as the der. only had about 500 miles on it without any dings or damage.
    Other than, that, I haven't/wouldn't change my set up. It's just too awesome: Mach 429 Aluminum.
  80. #280
    Aug 2010
    Had my LBS order me a CC DB Air CS…..getting rid of my Float X…it is on Ebay as I type this. Lubed up my clevis pin and retorqued to 24nM instead of the old 12nM.
  81. #281
    Got mine out of the garage today and rode around the neighborhood, felt good. Crashed hard 6 weeks ago and broke 6 bones, but I'm working my way back.
  82. #282
    Binned
    Nov 2008
    Quote Originally Posted by panchosdad View Post
    Ouch! Heal well and please take it slow.
  83. #283
    Bonking ... not feelin' well :cryin:
    Found the source of my creaking.
    Right where there is now an extra plate welded (or the retrofit kit )
    Ordered a replacement used frame because I can't afford new right now.
    I'm going to make my own brace to weld in there and make this bike the mini-park / shuttle bike.
  84. #284
    Nov 2007
    Brutal! But, wouldn't cracking of that nature be covered under warranty? Worth asking the question, in any case...
    Best of luck, either way!
  85. #285
    Quote Originally Posted by Isildur View Post
    Over 50, so I think the warranty has run out.
  86. #286
    v2.0
    Still needs tweaking, the stem that came with the frame/fork is just way too short. I blame it for my crash that happened on the way home from the trail. Hopefully the ol'Pelvis heals quickly. I need to work to pay for it.
    This one is my XC firebird. The old frame, once repaired, will be the shuttle/park pig.
  87. #287
    Feb 2014
    Swapped out FSA handlebars for Answer Protaper SL
    New black Pivot grips
    Tidied up cables with cool cable tie trick.
  88. #288
    Feb 2014
    Added Answer Rove XC 90mm stem for good measure...
    What have you done to your Pivot Cycle lately?-imageuploadedbytapatalk1414070127.527450.jpg
    What have you done to your Pivot Cycle lately?-imageuploadedbytapatalk1414070148.128659.jpg
  89. #289
    Cracking
    I think my 2014 429c is starting to crack, hard to tell if it's the paint or the frame cracking!!
    Attached Thumbnails Attached Thumbnails What have you done to your Pivot Cycle lately?-p1060704.jpg
  90. #290
    The only way to know is to sand the paint off lightly and inspect the layup directly.
    I'd take it back to your LBS and get them involved.
    Safe riding,
    Vik
    www.vikapproved.com
  91. #291
    Binned
    Nov 2008
    dgw7000, send those pics to Pivot. Let us know what they say.
  92. #292
    Taking it tomorrow again, I told them that Pivot has I year Warr. on paint they did not know that. If indeed it's the frame that's cracked it will still be Warr. Bike is only like 3 months old, either way I should get a new one. I just can't go without this bike even one day I love it that much!!
    Just added Pike fork, Renthal Apex stem 90mm only 148g and Syntace Vector carbon bar. Bike is better than ever!!
    Attached Thumbnails Attached Thumbnails What have you done to your Pivot Cycle lately?-p1060714.jpg
  93. #293
    Also just getting RockShox Reverb dropper post tomorrow!! Can't wait!!
  94. #294
    Mar 2014
    Sorry to say it, but those cracks are at high stress points. It is very likely the carbon starting to fail. The paint wouldn't crack that way if the carbon was in perfect shape.
  95. #295
    That's a good point!! I am a bit upset that only 3 months old and having this happen. Hopefully Pivot will do the right thing.
  96. #296
    Binned
    Nov 2008
    Quote Originally Posted by dgw7000 View Post
    They will.
  97. #297
    Binned
    Nov 2008
    Oh, I almost forgot. I changed saddles on my alloy 429. I sat on my buddy's bike a few weeks ago which had a WTB Vigo on it. It was so comfortable that I didn't want to get off of it so I got one for mine.
  98. #298
    New fame on the way!! Pivot great customer service!! They must keep Warr. stock!!
  99. #299
    Mar 2014
    Great!!!
  100. #300
    Nov 2007
    Over the last couple of weeks I've changed pedals and upgraded to Pikes. Riding so much better now!
    Next up is an DB Inline as soon as they're in stock over here in Oz
    What have you done to your Pivot Cycle lately?-dsc_0232_1.jpgWhat have you done to your Pivot Cycle lately?-dsc_0241_1.jpgWhat have you done to your Pivot Cycle lately?-dsc_0323_1.jpgWhat have you done to your Pivot Cycle lately?-dsc_0335_1.jpgWhat have you done to your Pivot Cycle lately?-dsc_0336_1.jpg
Members who have read this thread: 58
