Results 1 to 5 of 5
    Too much sag in the rear of my Firebird.
    I have a FB with a DHX 50 shock. It's a 2013 bike. Recently, the shock won't hold a 30% sag. I can pump the thing up to 240 lbs and it still sags to over 50-75%. I weigh 220. I am putting 150 lbs in the boost chamber. Is my shock toast, or am I doing something wrong?
    Proud Thunderchicken ownr
    Reputation: btibben's Avatar
    I run 170psi in my main of my DHX Air 5 and 180psi in my boost (according to my gauge). I'm only 175lb riding weight so I'm guessing you may have yourself a leaky seal.
    Common sense is not so common - Voltaire
    Never underestimate your own ignorance - Me
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Def sounds like the shock has a problem. On that bike you'll get the 30% sag with air pressure pretty close to your riding weight.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    So.... what do I do? Should I send the shock back to Fox? I assume they warrantee their products?
    Pivotal figure
    Jan 2003
    Yeah, I'd start by calling your LBS and see if they can take care of it (getting the RA#, shipping, etc). If you don't have a shop nearby, you can call Fox and talk to them about the issue and they'll help you out. I'm not completely sure what the warranty policy is with suspension on a bike but I'd assume it'll be covered.
  1. 203mm rotor on rear of 135mm Firebird?
    By honkinunit in forum Pivot Cycles
    Last Post: 03-13-2013, 09:48 AM
  2. Firebird rear triangle
    By btibben in forum Pivot Cycles
    Last Post: 11-07-2012, 12:47 PM
  3. why the rear shock problems on firebird?
    By kotajack in forum Pivot Cycles
    Last Post: 07-16-2012, 10:14 AM
  4. Rear wheel options for Firebird
    By mmaneul in forum Pivot Cycles
    Last Post: 07-14-2012, 03:53 PM
  5. FD Bolt Hitting Rear Triangle on Firebird
    By half_man_half_scab in forum Pivot Cycles
    Last Post: 04-20-2012, 04:02 PM
