Results 1 to 5 of 5
    JordanMy
    Reputation: Jordan Wong's Avatar
    Jun 2014
    Tidy up my Mach 6 cables
    2 cable Ties & 2 10mm cables which I cut out from old/unused video cables, just pull out the copper wires.
    This is how the cables run when you sit on your bike
    Attached Thumbnails Attached Thumbnails Tidy up my Mach 6 cables-20140608_173716.jpg
    Thank you
    thanks for sharing
    Reputation: SoCal-Rider's Avatar
    Thanks for this. I went ahead and did the same thing. No internal routing. Cross the cables just slightly without a rider, so they cross and bow out the opposite sides like shown. Seems to work nicely.
    I put a piece of the down tube rubber guard material on the shock on the bigger, black area and clear protection on the body to protect from cable rub.
    Feb 2010
    Isn't that how they are supposed to go? Mine are like that, works fine. The crossover means they don't bow out very much. The only thing I am watching for is rub on the shock/frame etc.
  1. Pivot Mach 427 - Mach 4 conversion
    By kleinhead in forum Pivot Cycles
    Last Post: 03-24-2015, 02:14 PM
  2. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  3. Replies: 26
    Last Post: 09-27-2013, 01:55 PM
  4. Mach 4 and Mach 5.7 Frame Weights? (Alloy)
    By ccarbot in forum Pivot Cycles
    Last Post: 07-07-2013, 04:58 PM
  5. Replies: 7
    Last Post: 02-18-2013, 11:44 PM
