Page 2 of 3 FirstFirst 123 LastLast
Results 101 to 200 of 238
  1. #101
    Aug 2013
    i have ordered and paid for a ccdb air cs 2014 215x63 for my new mach 6 and here is the surprise (cane creek answer )
    We just heard from another customer with a Mach 6 that the Medium and Small frames are compatible with the DBAir. You will need to order the BAD0919 which is a specific version of the DBAir-CS that has a 15mm open end-eye. The standard 215 x 63 shock will not work with this frame.
    I AM ****ED spent a lot of money and now canīt use it
  2. #102
    Reputation: wilks's Avatar
    Tell me bad things about the Mach 6
    Surely you can change the order?
  3. #103
    OriginalDonk
    Reputation: OriginalDonk's Avatar
    I know of a few people, myself included, considering running something other than the lauded Float X. I'm currently trying to work out what shocks are frame compatible (i.e. clearance for piggy back), what shocks require different hardware, and if the required hardware actually exists. Sounds like a specific 15mm open end-eye CCDBA is required per Cane Creek (thanks for doing the leg work Goyayago, hope you get what you need). Not sure if the standard BOS Kirk is compatible either. I know Fox, Rock Shox, and Marzocchi use similar standards and may be the easiest transitions. Keen to see what people hear from companies, LBS's, distributors, and the great KenBentIt as it comes through.
  4. #104
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    The key thing to remember on the Mach 6 isn't so much the shock hardware (the front mount is a very standard 8x22mm) it's the size of the shock body where the rear hardware would normally go. With the Mach6 there is NO shock hardware on the rear mount, just the "pin" that comes with the bike and replaces all the shock hardware. Our stock shocks come with no hardware or bushings in the rear position. The eyelet needs to be the correct ID (I need to double check that value but I "believe" it's .578")and the shock body needs the correct width/thickness at the eyelet (.500", 12.71mm). I've seen a pic with a Vivid air on a Mach 6 (pretty sure the frame was a Large). From what I've heard, the BOS uses a thicker shock body at the eyelet (14mm Vs 12.71) so it will NOT work. The best option is to email or call before ordering a shock so you don't end up with something that won't work.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
  5. #105
    Do you have any idea if the Monarch Plus will work on the M6?
  6. #106
    Quote Originally Posted by goyayago View Post
    I am sure that if you call Cane Creek to discuss the situation they will work with you. I had a similar issue with my I9 hubs and they worked it out for me very quickly.
  7. #107
    Pivotal figure
    Jan 2003
    I'm 99% sure the Monarch will work fine since it uses the same size bushings and it's "footprint" is even smaller than a Vivid Air (which I've seen on a bike).
    Quote Originally Posted by Salespunk View Post
  8. #108
    Quote Originally Posted by aevanlloyd View Post
    Here is what is wrong withe Mach 6: The color options are terrible. Where is the green used in the 429C? Where is the Solar Orange from the Les? How about the white/blue from the Phoenix. The blue is a nice color, but the black is not my favorite. C'mon Pivot, would it kill you to give us more color options? Even options you use in your other bikes?
    I find it strange you say this TBH because other manufactures do not give more than three colours any more and they dont give the same colours as they do with their other models.
    I agree that there is to much going on with all the yellow but get the all black if thats a problem!
    Santa Cruz and intense only offer one or two colours on each frame and they are normally very similar and not the same as another model!
  9. #109
    Reputation: DrewBird's Avatar
    Quote Originally Posted by stejam View Post
    I dont think we can fault Pivot for the number of colors offered, but their paint schemes are not my fave. This is personal preference obviously, but I love the more simple and elegant graphics of the Bronson and Mojo HDR. Solid background with large contrasting stripes or color blocks in a couple areas is a cool look. Pivot gets a little carried away with angular blocks of color, and the absurd number of logos is just ugly.
    My M6 will be stealth black. I think the lines of the bike are so cool and distinctive there's no need for garish colors...
  10. #110
    Reputation: vikb's Avatar
    I think the issue for people is there are really 2 black colours and one bright colour in the M6. One black and two other colour options would have satisfied a bunch of people in this thread without needing extra colour schemes.
    Safe riding,
    Vik
    www.vikapproved.com
  11. #111
    Quote Originally Posted by vikb View Post
    This reminds me of a tidbit I heard while demoing an M6 at Bothell Ski & Bike (aka bikesale.com, one of the largest Pivot dealers). They said they were not spec'ing xx1 or x01 on blue M6s because the paint was actually enough to cause a clearance issue with the rear cassette. I wasn't totally clear on where this issue would arise, and I have to think they'll fix this by masking the affected area soon.
  12. #112
    Pivotal figure
    Jan 2003
    Quote Originally Posted by DrewBird View Post
    We were having variances with paint thicknesses on the Blue frames but those have been addressed. I just verified that a Monarch Plus will def fit the frame. Also double checked my numbers for the pin diameter and it's 15mm. So any shock needs to have a 15mm eyelet and the body needs to be .500" to fit into the clevis.
  13. #113
    Awesome info. One other question, have you heard any other reports of clearance issues with XX1 and I9 hubs? My 10t is virtually unuseable with this setup, but was fine with the DTSwiss setup. I guess I can just throw a washer in there, but I hate hack fixes.
  14. #114
    Reputation: Yody's Avatar
    Yeah all the logos make it look like a trek road bike. yuk. I guess with all the similar looking bikes out there (with the shock mounted in same position, similar downtube, swingarm, etc. They want to make theirs stand out....... still looks like a road bike tho
  15. #115
    Quote Originally Posted by Yody View Post
    You must see some strange road bikes???
  16. #116
    lol i mean the graphics
  17. #117
    HAHA Sorry I see :-)
  18. #118
    I dunno, I think the M6 is fairly unique looking. S-curvy down tube and up-curving top tube/seattube junction looks a little like a Stumpy FSR I guess. But the pivots and links in the back are unique, and the overall look of the rear end is very cool in an industrial-chic kind of way. If it were up to me I'd highlight that with some ano on the links or pivot points. Maybe they'll offer those for after-market pimpin' at some point.
  19. #119
    Feb 2013
    I think what is going on here is that when people are considering a large purchase such as this, there is a natural tendency to evaluate the purchase by seeking out things in the (+) and (-) column.
    I find it hilarious (and satisfying since I'm buying one) that the only negative thing anyone can find is personal preference on the graphics. This isn't a beauty contest or accessory for me, its an all mountain shred machine and I happen to think its good looking and in line with the industry as far as graphics. If you don't love the graphics there is the stealth black. Problem solved. Don't even get me started on the lines of the bike, its downright dry-humpable.
  20. #120
    Reputation: jazzanova's Avatar
    Will a Mach6 complement a Solo (or in my case 650b TRc) nicely? What do you guys think?
  21. #121
    Quote Originally Posted by markmyers View Post
    i think what is going on here is that when people are considering a large purchase such as this, there is a natural tendency to evaluate the purchase by seeking out things in the (+) and (-) column.
    I find it hilarious (and satisfying since i'm buying one) that the only negative thing anyone can find is personal preference on the graphics. This isn't a beauty contest or accessory for me, its an all mountain shred machine and i happen to think its good looking and in line with the industry as far as graphics. If you don't love the graphics there is the stealth black. Problem solved. Don't even get me started on the lines of the bike, its downright dry-humpable.
    well said!!!
  22. #122
    Nov 2013
    power ranger fan, holy crap I laughed hard when I read that
    I have too many bikes, but it's not enough
  23. #123
    Pivotal figure
    Jan 2003
    We actually just had an I9 wheelset in to verify the setup worked OK. The spacing measured the same as the DT and Stan's wheelsets. I don't have that much experience with I9 hubs though, do they offer different models?
  24. #124
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    My decision to go with the M6 over the Bronson came down to, silly enough color choices.
    The Bronson had the threaded BB, reliable pivot setup. Good cable routing. Availability and price
    The M6 had the DW and better geo (which is a big one for me).
    It was really close, so it came down to looks. The M6 in Stealth came out on top. My bikes have usually been red or black. The Bronson's colors were not good - like SC was trying to hard to go out of its way to be different with those funky, trendy colors.
    I do agree that Pivot advertises way too much on their frames.
  25. #125
    fc
    fc is online now
    honcho Administrator
    Reputation: fc's Avatar
    Aug 1996
    Make no mistake... it's a great bike. This thread is really for folks who know about the awesome qualities of the bike and are getting ready to dip into the kids' college fund.
    Like I said earlier, it would be great if every bike had a thread like this so it cuts to the chase of gives the 'soon to be' buyer that they're not making a mistake.
    fc
    IPA will save America
  26. #126
    Quote Originally Posted by kenbentit View Post
    Mine are the latest Torch series. I will send some pictures to the Pivot support alias. Might be a hub issue too.
  27. #127
    Pivotal figure
    Jan 2003
  28. #128
    This is sort of lame to post, since I don't even own the bike ... but right off the bat, the fact that it doesn't have a water bottle cage mount inside the front triangle is a huge minus for me...I only want it for 5% of the rides I do, but when I do, I don't think any other option is as good. I know its a tight squeeze, but other bikes ( Spec. 29 ) managed to squeeze one in there...maybe Pivot didn't try hard enough?
  29. #129
    Nov 2013
    most riders wear backpacks with reservoirs as was pointed out in several of the forums about this bike and others. I can't remember the last time I bought a bike, even the Spec 29 and I have 2 of those, when it had a bottle cage on it already. Plus it's about $10 if u really want one.
  30. #130
    Quote Originally Posted by slcpunk View Post
    This is sort of lame to post, since I don't even own the bike .....maybe Pivot didn't try hard enough?
    Last thing I want a bike company doing is compromising something else to fit a water bottle cage inside the frame on a 6" travel bike.
    Some suspension designs and frames allow a bottle to fit easily...if that's the case I have no issue with providing mounts for one, but this is one of the lowest priority items I would want considered.
    Safe riding,
    Vik
    www.vikapproved.com
  31. #131
    fc
    fc is online now
    Aug 1996
    Quote Originally Posted by deerock View Post
    What he's saying is it is not possible to put a water bottle cage on this bike.
    The All Mountain bikes seem to be split now on allowing a bottle cage or not. And the the cage at the bottom of the down tube does not count as it is BS.
    So it's a good consideration to note for riders who like the option of using a bottle sometimes.
    fc
  32. #132
    Does anyone have experience routing a stealth dropper post on an M6? Routing goes down the DT, then up the ST. Is there some kind of baffle inside the frame so the cable will automatically make that turn, or do you have to fish it around the corner using the BB shell for access? If it's the latter, wouldn't this require not only removing the cranks but partially disassembling the PF BB? Hoping that's not necessary!
  33. #133
    Non issues on the water bottle for me as I always ride with a pack for tools, extra tube, pack a phone, nutrition, etc. I wouldn't feel comfortable even doing a quick loop by my house without having tools and a spare tube.
    Really simple to route the cable for the dropper. Just feed it in the hole and it will come up through the seat tube. There is a baffle the handles the whole thing, super easy.
  34. #134
    I thought about chopping the sworks enduro in for a m6 on Sunday, Friday afternoon and I've built a blue m6....sweet!
    Now,can we change this thread to...tell me Only good things about the m6?
    Coming off the enduro this feels so different, i understand the qualms about the SA. seating position it's way back as oppose to the enduro's weight forward style.
    Seriously cool bike,can't wait to get up the mountain.
    I thought the frame comes with a headset? Had to go to 2 lbs earlier for a hope pic,n,mix when i realized it didn't.
    Also, how am i going to route a reverb stealth? Wire in from the front, tape, then pull it backwards or won't it fit??
    P.s mavic crossmax enduro with xx1 won't work unless spaced out with washers.. that really grinds my gears!!
  35. #135
    Pivotal figure
    Jan 2003
    The Reverb will fit but I honestly don't remember what the installation procedure was. You could email RS for info but I remember it being pretty straightforward (we installed one for testing but I wasn't working directly on that project at the time, just in the stand next to mine). The frames only come with a shock, seat clamp, der hanger and RWS. The headset is a separate item or it comes as part of a frame kit (with fork).
    Quote Originally Posted by waldo1 View Post
  36. #136
    Congrats, you are going to love it. The Stealth should have a quick disconnect, but not sure if that will fit through the internal routing. If not they are super easy to bleed, just make sure you read the instructions.
    As for the bottle cage, I run one on the DT of my HD without issue. Us the new Camelback bottles and you don't even have to worry about cleaning it off before drinking. Reaching it is not an issue either, you just can't be pedaling, but you don't need to stop.
  37. #137
    That's the issue. The quick disconnect won't fit through the hole and it's crimped.I could disconnect from the lever side but that means routing it in reverse.
  38. #138
    Aug 2013
    I have found the solution here.
    Kit Roller Amachete
  39. #139
    Pivotal figure
    Jan 2003
    I'm not seeing how that will work for you in this case? The rear mount on the Mach6 uses a 15mm pin that fits directly into the shock body with no bushings at all. That pin countersinks into the clevis which is how it resists flex/twist. Here's the parts list pdf so you can see the piece I'm referring to. It's part#7 "Mach Clevis Shock Pin".
    http://www.pivotcycles.com//up/file/...013.10_.5_.pdf
    Kit Roller Amachete
  40. #140
    Reputation: Joel RW's Avatar
    Undo the reverb remote, straighten the cable as much as possible and with a torch feed it down the seat tube into the internal routing pipe, it took me 5 minutes and im no pro
    Pivot mach 6!
  41. #141
    BarBanger
    This is what I did w/ my Reverb Stealth. There's no other way. It forces you to bleed it after install and the Connectamajig becomes a moot point on this bike, but it was no biggie.
  42. #142
    Keep on Rockin...
    Nov 2003
    Not that it matters much right now as my M6 is paid for and currently cruising cross country in the big brown Santa sled to my doorstep buy I'd still like to hear thoughts from Pivot riders. (Can't recall if I asked this here already, so if I did sorry.)
    Bearings: How is the durability on Pivot's pivots? Are they a squeaky bunch that needs frequent replacing? If so, is it a bearing press project, or a shade-tree mechanic job?
    BB: Any word on issues the PFBB? Are the Shimano BBs and drive trains playing nice with this abomination?
  43. #143
    Reputation: robertj's Avatar
    Feb 2005
    My 3yr old 429 has the original bearings and still riding quiet. I just take the axels out periodically, clean and reassemble.
    I live in a year round riding area, and save the trails when they are (infrequently) wet, so I can't speak to durability during wet season riding, or surfing the bike through rivers, etc. I can't stand squeaky, creaky bikes. I've been known to be hard on frames so when I hear a creak, I'm stopping to check for frame cracks (aluminum frames). You can see how this would be an issue with a creaky bike, as I'd be stopping to check things out all the time! LOL
    I also don't wash my bikes, only dust them off with a rag, so I can't speak to durability with frequent washing.
    My PFBB (SRAM) on my 429 is also the original one. I used the same one on my Mach 6.
    Over the 3yrs, my 429 was ridden ~2-3 days/week; another bike was ridden ~1-2 days/week over the same time. So lots of trail time on the bearings.
  44. #144
    Reputation: k2rider1964's Avatar
    That's all good to know...I can't stand squeaky bike either. Drives me batty!!
    Quote Originally Posted by robertj View Post
  45. #145
    Jan 2014
    Squeaky
    Tell me bad things about the Mach 6-blizzard-silhouette.jpgTell me bad things about the Mach 6-blizzard-anticipation.jpg
    Too squeaky, M6 cried all night because of the blizzard. I think the SnowBlower was teasing her.
  46. #146
    Any comments on the rear end stiffness of this bike on the trail? I got an anonymous tip to check out the "grab the tire and seat tube and twist" test. I got my hands on one this weekend, and I was frankly shocked at how much the yoke that actuated the shock moved.
  47. #147
    Pivot isn't known for flexy bikes, haven't heard any reviews of it being flexy?
    friends don't let friends Fred
  48. #148
    True, but their bikes usually attach the shock directly to the rear triangle. As to the reviews, most reviews are from people who bought them or bike magazines. Hard to interpret what they mean. I can say that the particular bike I had my hands on had the flexiest rear triangle of any dual short link bike I've ever dinked around with. Maybe it doesn't manifest itself on the trail, but I'm just reporting what I saw.
  49. #149
    Then you never messed with an original mojo sl or an aluminum intense tracer......but I hear you on "influenced" reviews
  50. #150
    Keep on Rockin...
    Nov 2003
    Headset question (x post from M6 pics thread)....
    The stock headset that comes with a build kit... Mine appears to have about a 2.5mm space between the top cap and flange of the head tube insert. There is a thin rubber gasket in that space, but the gasket does not nearly fill the void. The gasket seats upward into the recess of the top cap.
    The space looks open enough to let in a lot of water and grit.
    Am I missing perhaps some other seal or spacer/washer?
    Thanks.
  51. #151
    Pivotal figure
    Jan 2003
    Here's the stock headset installed on my Les (same one we use on the Mach 6). There is a small gap but the inner surfaces interlock to keep crud out. Hopefully the pic is clear enough....
    Attached Thumbnails Attached Thumbnails Tell me bad things about the Mach 6-headset.jpg
  52. #152
    Keep on Rockin...
    Nov 2003
    Doesn't look like there is a spacer beyond the rubber gasket.
    My fork steerer isn't cut yet and thus not torqued down. Perhaps my compression ring will seat further in when I get the star nut in and I torque it all together.
    If there is not another spacer that would have to be it.
    Thanks.
  53. #153
    Quote Originally Posted by Miker J View Post
    Thanks.
    I've run into this a few times before with a few different makes of headsets, and it just needs to be torqued down and settle in.
  54. #154
    Pivotal figure
    Jan 2003
    Yeah, the silver split washer will fit pretty snugly into the topcap once it's torqued down.
  55. #155
    I haven't built mine yet and haven't even gotten to ride one. But the colors aren't great. I opted for paint this time since my last carbon frame was bare. The only painted one is the blue. The paint is excellent quality, however, its like a frigging billboard advertisement. Graphics of Pivot, wheel size, suspension type, patents. I'm sure this also added to the costs as well. I'm not a flashy person and I think I'll be just a bit self-conscious riding around on this frame.
    Don't get me wrong, it looks nice but just a bit much for my taste. I don't think I've ever seen a frame with so much on it, besides maybe at the races for pro riders. But those factory rigs ARE trying to advertise.
    We Ride In God's Country!
  56. #156
    Quote Originally Posted by myitch View Post
    So is Pivot.
  57. #157
    I agree, which is why I went with Stealth. Personally, I think it looks bada$$ and really lets the beautiful lines of the frame do the talking:Tell me bad things about the Mach 6-img_1494.jpg
  58. #158
    Lightly salted
    Reputation: fuenstock's Avatar
    I kind of feel the same way about the busy graphics. Are they just stickers, stickers clear coated or decals under clear coat? I wonder if they are easy to remove? On my HDR frame I have it in reverse P and removed a lot of the P no problem for a more subtle look.
  59. #159
    Reputation: Swissam's Avatar
    I agree, which is why I went with Stealth. Personally, I think it looks bada$$ and really lets the beautiful lines of the frame do the talking:Click image for larger version.
    Damn that thing does look badass.
    One more bad thing about the M6, I can get the frame for the same price as an Uprising with the FloatX. Before the M6 was just over my budget but now we have a new dealer here in CH that's selling it for 600CHF ($675) cheaper than the other Pivot dealer (who thought he could charge a small fortune since he was the only Pivot dealer.
    Anyways now that the M6 frame is the same price as the Uprising I have a feeling I'm going to lose lots of sleep over this.
  60. #160
    fc
    fc is online now
    Aug 1996
    Quote Originally Posted by fuenstock View Post
    They are painted on!!!
    fc
  61. #161
    fc
    fc is online now
    Aug 1996
    I got my cable routing sorted now that I have the zip tie kit.
    I got the cap too for the front derailleur mount.
    I've been riding the bike a ton and it is a dream. I'm not too concerned about the high-ish BB now. I ride it deep in the sag and the BB height seems just right, even for Norcal.
    Seat tube angle is indeed slack-ish. A zero-offset post is key I think. I have an offset Specialized Blacklite post for now and I just filpped it around.
    Attached Thumbnails Attached Thumbnails Tell me bad things about the Mach 6-img_2438.jpg
  62. #162
    Reputation: fresh tracks's Avatar
    Feb 2005
    Mach 6 versatility towards the trail/xc spectrum?
    I'm interested in how versatile the mach 6 is. Where I ride the trails are either grit (hard or "kitty litter" over hard) or granite. Dirt doesn't exist, I never have to clean my bike except for dust... The max vertical on any particular run is 200m, so the ride is a lot of climb up, bomb down, then climb back up again. The trails are super smooth xc type (climbs) and rough granite rock gardens and rock features (descents). Drop offs are 3 foot max. I need a new bike that balance these two the best - climbs fast and handles the rough. It sounds like the mach 6 does the downs brilliantly. How good is it on the ups? I rode a tallboy LTc the other day which seemed to get the compromise right, but I'm not a 29'er kind of guy - that bike wasn't very playful and did not want to leave the ground easily, which made the downs a bit boring.
  63. #163
    Francois, why are the listed specs and the pictures different on the conpare-o first look? Is the weight you publish of the bike pictured or the bike with the listed specs ? Very confusing.
  64. #164
    Reputation: Lpcunity's Avatar
    Jun 2010
    What is the largest(width) rear tire that fits on the M6?
  65. #165
    If you get a blue M6 and don't like the logos you can get custom vinyl decals made for a few bucks at a sign shop either with your name, bike club or just plain and match them up with the bike's colours so it looks pro and yet there are fewer marketing slogans on your bike.
    Safe riding,
    Vik
    www.vikapproved.com
  66. #166
    As long as it looks pro.......
    Nice KOM, sorry about your penis.
  67. #167
    Quote Originally Posted by Mrwhlr View Post
    Go to a good sign shop and you shouldn't have any issues. Have a chat with the guy/gal that's going to help you and assess their talent level.
    Decals are also peel off so you can change it up every season if you like.
    Safe riding,
    Vik
    www.vikapproved.com
  68. #168
    Keep on Rockin...
    Nov 2003
    Quote Originally Posted by Lpcunity View Post
    I have my bike sitting with a 2.4 Vee Rubber Trail Taker on a Flow EX. There is clearance but not enough for me to feel safe riding it.
  69. #169
    Lower link area looks like this after few months of use..
    Sure it's only cosmetic, but my previous Machs didn't have this feature..
    Attached Thumbnails Attached Thumbnails Tell me bad things about the Mach 6-image.jpg
  70. #170
    Nov 2013
    I've had it for 3 or 4 months now and I don't have any signs of that. Wonder if you caught some pop rocks in there? interesting though.
  71. #171
    Quote Originally Posted by Quadro View Post
    Yikes! Is there enough clearance for some thin protective tape to be installed?
    Safe riding,
    Vik
    www.vikapproved.com
  72. #172
    How did that happen?
  73. #173
    I doubt any tape could help.
    Dirt and small rocks just get wedget very easily in that area because of the design.
  74. #174
    I have the same thing. A lot of stuff gets kicked up there. Nothing big enough to do damage beyond paint scratches is going to get in.
    You should be proud of those. It is like you wife/GF leaving scratch marks on your back. Just shows you are riding her right!
  75. #175
    If it scratches through paint, it will eventually scratch through carbon once the paint is gone.
  76. #176
    Quote Originally Posted by hillharman View Post
    Carbon is much harder and tougher than paint. That's why they don't make bike frames out of paint. I think it'll be OK.
  77. #177
    Have you ever abraded carbon with coarse rock? It's not that difficult. Carbon isn't harder than most rocks, and that's the relevant comparison. I assure that anything capable of doing that to paint can abrade carbon in a reasonable amount of time.
  78. #178
    Yeah i've got a few marks there, when you clean your bike run a brush through there because i've had some small rocks get lodged.
    Pivot mach 6!
  79. #179
    I'm going to put on some "loop" portion of velcro. Velcro uses two sides, hook and loop. You'd probably just have to replace the velcro every now and then. I'm putting the loop velcro on the cable near the shock mounts and on the shock itself. It really sticks well and is great on reducing the rub. I've also used it on other bike's chainstays right near the cassette to keep the chain from nicking, where inner tubes don't fit (You know, the inner tube chainstay wrapping technique). Worked great there too.
    The velcro loop also conforms well to curved areas. Just cut at the corners and form.
  80. #180
    +1 - the layup might be thicker in that area to deal with abrasion, but if the clearance exists I would throw some tape on there to prevent the damage.
    Safe riding,
    Vik
    www.vikapproved.com
  81. #181
    Didn't want to start a new thread for this question...figured this thread was the right place...
    My GF got a M6 w/ XO1 kit. The Fox suspension seems to have a lot of stiction. Is that just life with new Fox stuff and she should ride it to break it in? Or should we lube the seals or even get the fork serviced???
    Suspension Werx in Vancouver has posted that a number of Fox forks needed service brand new out of the box to operate properly.
    Not dying to spend $$ to service brand new parts, but at the same time not wanting to save $50 and have a $6K+ bike that doesn't perform.
    For those of you who got the Fox forks on your M6's how were they new?
    Safe riding,
    Vik
    www.vikapproved.com
  82. #182
    bad reputation
    Reputation: turfnsurf's Avatar
    Nov 2007
    Slightly off topic Vik,
    I had a Bronson X01 with Fox Suspension. I felt the same thing when standing and pushing the bike into the travel. It's not as bad once you're actually trail riding, then again its not great!
    I'd recommend running everything a little firmer than standard sag for a few weeks of break in and reevaluate after a few weeks. I totally get the frustration if spending money to tune new parts...that's why I was stoked when the guy that bought my Bronson frame wanted the Fox fork too!
  83. #183
    Most of the new Fox stuff I've felt in the stores felt like this, and so did my 2013. I've had good luck with Finish Line Stanchion Lube. It's basically liquid Teflon and it can help to condition sticky seals. I dripped a bit on before each ride, and the effect is noticeable and immediate. Honestly, though, sell it and get a Pike.
  84. #184
    I have a Pike for my M6. I tried to work with my GF on a custom build, but her brain overloaded before we decided what cranks to run so I gave up.
    Worst case we'll send the fork and shock to Avy for a custom rebuild in the fall. We are keeping our Nomads as winter bikes so she can pull her M6 apart in Oct/Nov and we will likely end up in Sedona at X'mas where we can collect the suspension bits from Avy without having to deal with shipping back to Canada.
    I may well be sending my Float X to Avy at the same time.
    So my mission is to get her setup as best as I can between now and the end of the summer. Swapping in a Pike isn't one of the options. She is maxed out on bike $$ for many months.
    Safe riding,
    Vik
    www.vikapproved.com
  85. #185
    I hear you. My wife and I are currently bike poor right now. Definitely check out the lube. It gave me some satisfaction.
  86. #186
    It will definitely break in over time, but will never get to Pike levels of plush. Pulling the fork apart new is not a bad idea since there have been reports of them coming dry/low oil levels in some instances.
  87. #187
    bad reputation
    Nov 2007
    ...Pulling the fork apart new is not a bad idea since there have been reports of them coming dry/low oil levels in some instances.
    I've been suspicious of that on their Fork/Shocks for a while now. Can't help but wonder if it's just to help keep their "claimed weight" on their products low...
  88. #188
    We'll probably get her Fox stuff serviced. Given the cost relative to the price of the bike it's small change to ensure it is running properly.
    Safe riding,
    Vik
    www.vikapproved.com
  89. #189
    You can do an oil yourself in a matter of minutes if you have any mechanical inclination, and I'm sure you do.
  90. #190
    +1 - I have never serviced my suspension, but this may be the opportunity to learn.
    Safe riding,
    Vik
    www.vikapproved.com
  91. #191
    You'll be shocked when you see how easy it is. One beer job once you've done it before.
  92. #192
    Yep super easy to change the oil. Even changing the seals only add about 5 minutes. I use some PVC pipe connectors and a mallet to press the seals back in.
  93. #193
    I'm off to take some newbs into the mountains on a bikepacking trip. I'll check out some Fox fork servicing vids online and see what's what Sunday PM.
    Enjoy your weekend folks.
    Safe riding,
    Vik
    www.vikapproved.com
  94. #194
    Reputation: Trail Turkey's Avatar
    Mar 2014
    No wonder on the climbs at all!!! I went from back of the pack on my enduro to middle of the pack just because of how the bike climbs....Mountain goat!!!!
    Large Pivot Mach 6 Stealth/ XT /Self Build=28.4 LBS
  95. #195
    Quote Originally Posted by A.P. View Post
    Here's an alternative (better) cable routing for the Machs. Maybe not as photogenic as the Pivot routing, but much more functional when the suspension is working. No cable rub whatsoever.
    When I purchased the bike, my lbs mechanic asked me if I wanted the "Pivot routing" or the "Good routing"...
    I see the wisdom in your cable routing now that I have a M6 in front of me.
    I think maybe some of these stick on cable guides could be the solution to a clean looking bike and ditching the cable problems of running them over the shock.
    Safe riding,
    Vik
    www.vikapproved.com
  96. #196
    Im seeing the start of this on my ride, has it got much worse since this photo?
  97. #197
    That is a well designed pebble grinder.
  98. #198
    Is the new 650 Mach really that much different than the 26" Mach? Is this bike "that" much better or is everyone just rushing on the 650 band wagon. I ask because the geo numbers look very similar; half degree slacker, half inch longer TT, little longer wheel base and chain stay, higher BB.... It seems to be almost identical, but I don't remember people raving so hard on the mach 5.7. Unless the suspension action/curve is improved greatly?
  99. #199
    A lot of people built their 5.7c's up light. With 32s or Revs up front, light duty tires etc. The frame is over a pound lighter with 10mm less travel. My 5.7c has a 150mm Pike and 2.35 tires and is pretty capable. The Mach 6 is a more plush feeling ride and quite a bit more capable apparently. My Mojo HD is much burlier and more capable in the rough stuff than my beefed up 5.7c is and when people like salespunk say the Mach 6 is being ridden whilst his HDR is sitting in the garage I have to think the Mach 6 lives up to the hype. I'm desperate to try one myself.
  100. #200
    I've only had my Mach 6 for (5) weeks but so far there's nothing to complain about IMO. Like a few others, I'd agree there is graphic overload and I'm not a huge fan of the cabling routes but it's not something I would complain about either as it hasn't caused me any grief. The only problem with this bike so far is the owner isn't good/crazy enough to push it's limits
  1. Things Fitting Perfectly Into Other Things...
    By CHUM in forum Off Camber (off topic)
    Last Post: 03-23-2014, 05:54 PM
  2. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  3. Replies: 26
    Last Post: 09-27-2013, 01:55 PM
  4. Mach 4 and Mach 5.7 Frame Weights? (Alloy)
    By ccarbot in forum Pivot Cycles
    Last Post: 07-07-2013, 04:58 PM
  5. Replies: 7
    Last Post: 02-18-2013, 11:44 PM
Members who have read this thread: 4
