Results 1 to 14 of 14
    No Clue Crew
    Apr 2005
    Switchblade crankset considerations
    So, I bought the XT/XTR 1x model. It comes with an RF Aeffect cinch-style crankset and a 30-tooth cinch ring. Despite reports to the contrary, the ring did not come flipped from the factory. My chainline seems OK from a functional standpoint.
    I also own a RF Next crankset on a different bike. I'd love to be able to swap the two. So, I did a little disassembly today.
    IMG_1236 by dbozman1173, on Flickr
    IMG_1237 by dbozman1173, on Flickr
    As you can see, the Aeffect cranks don't have a "normal" RF 30mm spindle and the frame comes with a Shimano PF BB. The Aeffects also have a small NDS spacer (5mm) on the spindle and a mated DS spacer (10mm total width).
    The Next cranks have a 30mm spindle marked 68/73. Not sure where to measure from, but wouldn't these carbon cranks just swap right in with a swapped 30mm PF BB?
    And to follow up, would these Aeffects swap onto a standard threaded BB frame with just a Shimano BB swap?
    Just like a raindrop, I was born to fall.
    No you need a wider spindal from raceface and spacers for the 30mm spindle. I just swapped the affects to the next sl's on mine
    May 2005
    So the 2015 Next SL Cranks won't fit? I put in mine without the BB just to have a look about crankarm clearance and it looked fine to me.
    No Clue Crew
    Apr 2005
    Yep, visually it looks fine, though I can't tell about the Q factor or ring clearance by just eyeballing it.
    Involver: What BB did you use? And do you have a part number for the spindle you swapped?
    I used a raceface bb92 for the 30mm spindle. I'll get the part number for you tomorrow. I'll give the shop a call and get it for you. it is a different spindle though due to the q factor
    May 2005
    You got a different spindle for the old Next SL Cinch crank or the new Next SL G4?
    I have the G4 on mine but I believe you need it for the old next sl as well
    you need the spindle 30mm plus 143.5mm and i believe a 1.5mm and 11.5mm spacer in 30mm.
    No Clue Crew
    Apr 2005
    Thanks for checking.
    Quote Originally Posted by Blatant View Post
    no problem man
    Paterfamilias
    Feb 2006
    The Aeffect crank we use has the longer spindle. So no need to flip the ring.
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Nov 2016
    Quote Originally Posted by invol2ver View Post
    I just purchased the next g4 crank with the suggested spindle for my SB. What spacers do I need and which side do they go on?
    Mar 2012
    For those of you with the Next SL G4 cranks and the 143.5mm spindle, could you share your spacer configuration on each side? I upgraded my cranks from the stock Aeffect to the Next SL G4 (and the 143.5 spindle), but am not sure which spacer configuration to use to get the optimal chainline.
    Dec 2015
    does anybody know if a hope crankset would fit?
    Gesendet von meinem SM-G930F mit Tapatalk
  1. Rack considerations
    By Mr Magoo in forum Cars and Bike Racks
    Last Post: 08-09-2016, 03:09 PM
  2. Leadville aero considerations
    By InWyo in forum Endurance XC Racing
    Last Post: 06-08-2016, 01:25 PM
  3. Syntace cockpit for LES considerations
    By adinpapa in forum Pivot Cycles
    Last Post: 12-05-2014, 03:44 PM
  4. 142x12 rear considerations?
    By powderhound82 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-18-2012, 10:00 AM
  5. Considerations, need some opinions.
    By montananate in forum Specialized
    Last Post: 10-05-2012, 06:08 AM
