Results 1 to 7 of 7
    Feb 2005
    Removing firebird front der assembly
    Very basic question from a new firebird owner. I plan on running a 1x9 setup with chainguide. Is it acceptable...or necessary to remove the floating front derailleur assembly? It would seem so as it the chain plate, mount, and hardware are only relevant to the derailleur? I don't want to remove critical components though.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: Removing firebird front der assembly
    Yes i say go ahead and remove it, no need to keep the weight there. I did the same. Remove the spring first using some needle nose pliers.
    Reputation: crank1979's Avatar
    Feb 2006
    It all comes off without any problems when you fit the chainguide.
    dog
    dog is offline
    sit! stay!
    Reputation: dog's Avatar
    i would keep the plastic spacer thingy, though. I needed it for use with an ethirteen LG1.
    i need to develop my crashing skills...
    > /dev/null 2&>1
    Feb 2012
    Good point dog, but you also may want to play around with the spacer on and off - i have an mrp g2 sl. I started with the spacer on, then felt the guide was too far to the right, and dragged in the low gear. So i removed it and used washers to nudge the guide over to the perfect position.
    Feb 2006
    I just used the washers that came with the LG1+. I used the plastic piece when I put the front derailleur mount back on recently.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    If you haven't noticed already, the full length housing setup will let you remove the F. Der and shifter without disconnecting the cable which is pretty cool if you decide to put them back on later.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
  1. Replies: 30
    Last Post: 04-21-2017, 06:00 PM
  2. Need instructions on removing front tire....
    By johnd11 in forum Wheels and Tires
    Last Post: 08-23-2012, 06:29 PM
  3. Front Derailleur on Firebird
    By half_man_half_scab in forum Pivot Cycles
    Last Post: 12-02-2011, 09:29 AM
  4. Removing Lefty front wheel... GRRR!!!!
    By dinger in forum Cannondale
    Last Post: 10-19-2011, 03:01 PM
  5. Removing front derailleur
    By deadpool532 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-09-2011, 02:14 AM
