Results 1 to 5 of 5
    more beers, lees gears.
    Reputation: mattKHS's Avatar
    rear shock size on a 2010 Mach4
    Looking at a used 2010.5 mach 4, but it needs a rear shock. Anyone know the Eye to Eye and stroke i need? i know in 2011 they changed the stroke to 1.75".
    thanks
    A burrito is a sleeping bag for ground beef.
    Nov 2007
    Pretty sure it's the 7.875 x 2.25 (200x57) sizing, or at least I think I had a 57mm stroke on my '10 Mach 4.
    Haven't had it in a while though, so will have to check and see if I've got my old setup docs for that bike.
    Nov 2007
    Edit scratch that... Just looked at my old settings, and I've got 15mm for 30% sag, which must mean I had a 50/51mm stroked shock. Not sure on the I2I then now...
    c'est la vie
    Reputation: Maluco's Avatar
    7.5 x 2.0 shock size unless it is XS size frame. You may wish to have the shock tuned if buying aftermarket. Aftermarket Fox shocks come preset and may have too much compression and rebound to work well with the PM4.
    This chart is helpful for determining shock sizes:
    SHOCK CHART
    "Who are you?"
    "That's a long story." -Christopher Walken, The Prophecy
    awesome list. thanks. I wish manufactures would keep tech into up on their site longer.
