Page 2 of 2 FirstFirst 1 2
Results 26 to 48 of 48
  1. #26
    Quote Originally Posted by MntnMan View Post
    I love my M6, but the rear cable and hose routing is insidious. When the rear travel compresses, the hoses bow out/in and create all sorts of rubbing issues. I don't run the rear der thru the provided frame ports. I made a loop of velcro that extends to either side of the frame and placed it under the first cable clamp just forward of the front shock mount. Now the cables slide forward above the shock and thru the velcro loop when the shock compresses. No bow-ing. No hitting my legs. No problema.
    I am assuming that it doesn't rub the rear shock any longer as well?
  2. #27
    BarBanger
    Negative, Mike. I used a dual crown fork trick and double ziptied the cables. One around the shock can and one loosely around the cables, running the cable one under the can one first.
  3. #28
    Dec 2009
    Pic please
  4. #29
    Oct 2013
    pretty serious cable rub on shock canister these 2 days
    been riding the bike since mid jan, thought i got the potential cable rub spots settled with race shield stickers but the last 2 days of riding, the 2 cables that run under the frame got tangled in a fashion that caused the attached cable rub on my shock in just 2 days.
    I have since added a couple more race shields on there but my main concern is if the cable rub would have caused the canister to be compromised. I wouldnt want the shock exploding
  5. #30
    Pivot Mach 6 cabling question
  6. #31
    That is an interesting solution.
    Quote Originally Posted by stejam View Post
  7. #32
    It works perfect! It could be done in the same manor as the pipe on the link if i could be bothered to find some!
  8. #33
    Reputation: vikb's Avatar
    I'm glad it works, but the cabling hijinx needed for this bike make me want to cry.
    Safe riding,
    Vik
    www.vikapproved.com
  9. #34
    Cross-post from the M6 problems thread. This info belongs here:
    Quote Originally Posted by A.P. View Post
    Here's an alternative (better) cable routing for the Machs. Maybe not as photogenic as the Pivot routing, but much more functional when the suspension is working. No cable rub whatsoever.
    When I purchased the bike, my lbs mechanic asked me if I wanted the "Pivot routing" or the "Good routing"...
    I see the wisdom in your cable routing now that I have a M6 in front of me.
    I think maybe some of these stick on cable guides could be the solution to a clean looking bike and ditching the cables problems of running them over the shock.
    Safe riding,
    Vik
    www.vikapproved.com
  10. #35
    dis member
    Reputation: backpedal's Avatar
    I got a little crazy
    and made a couple of line routers for the rear derailer and rear brake line. I couldn't stand how the shock motion shoved those lines into, well, nowhere they had any space to move.
    Attached Thumbnails Attached Thumbnails Pivot Mach 6 cabling question-14156263047_c1ea343814_c.jpg
  11. #36
    Reputation: turfnsurf's Avatar
    Nov 2007
    I see the Passion Trail Bike sticker on that frame. Was Charles involved in that cable routing at all?
  12. #37
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Cable solution....
    Cable routing is something I'm finicky about and wasn't happy with the M6's. Now I'm finding it to be one of the best.
    I'd have to look again at exactly how I did it but rerouted the order of how the cables exit from under the TT. Now when the suspension cycles the cables bow in a horizontal, parallel, but opposite direction than they originally did. For example the cable exiting the left hole now bows to the right then redirects back to left. It takes up the "slack" perfectly so the bow barely protrudes.
    While it was a hassle to find the precise set up, it now works perfectly and gives the routing to the rear derailure a very direct line.
    A pic is worth a thousand words - I know. Will see what I can do.
  13. #38
    Pic pic
  14. #39
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    THIS is how it's supposed to work! Kind of like a scissor jack. Takes a little fine tuning to get the cable length right but it does work nicely.
    Quote Originally Posted by Miker J View Post
    Cable solution....
    I'm pretty picky
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
  15. #40
    dis member
    Quote Originally Posted by turfnsurf View Post
    Yes, Charles = Backpedal
  16. #41
    Pics
  17. #42
    Jul 2014
    Have you guys tried this?
    Attached Thumbnails Attached Thumbnails Pivot Mach 6 cabling question-shock.jpg
  18. #43
    In Search of Singletrack
    Reputation: shosan's Avatar
    good lord there are some really hideous cable routing here! I have a M6. I agree that it could be better...but...if you cut the cable housing to the shortest length possible in the area of the rear shock, and secure the housing to the rear triangle with the tie-offs (zip ties), there will be only a very little bit of bowing of the cable housings in the shock area. No need for crazy cable routing and 100s of zip ties all over your frame.
  19. #44
    Look my post ;-)
  20. #45
    Quote Originally Posted by backpedal View Post
    Hi Backpedal, how did you attach the gear clamp to the shock bolt? is the standard bolt or a replacement thats not countersunk?
    thanks,
    alex
  21. #46
    dis member
    I used a different set of bolts, scavenged off a Santa Cruz, then made a threaded sleeve to protect the threads in the frame and take up the space left by the smaller diameter bolt.
    https://www.flickr.com/search/?user_...ch6&view_all=1
  22. #47
    Thanks, would be a good mod if i can work out the parts!
  23. #48
    Edit
  1. Pivot Mach 429 Carbon - Size question
    By ozihotspudz in forum Pivot Cycles
    Last Post: 07-16-2014, 02:44 PM
  2. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  3. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
  4. Pivot Mach 5 Question
    By MTN DEW in forum Pivot Cycles
    Last Post: 04-20-2012, 12:52 PM
  5. Pivot Mach 5 rear shock PSI question
    By JonnyB76 in forum Pivot Cycles
    Last Post: 04-19-2011, 09:58 PM
