Results 1 to 8 of 8
    offroader
    Dec 2008
    pivot mach 5 rear tire clearance?
    What's the widest tire I can run without it rubbing?
    Quote Originally Posted by CupOfJava View Post
    Mine fits a 2.35 Schwalbe Hans Dampf with no issues. Nothing like a 26er for tyre clearance.
    offroader
    Dec 2008
    Quote Originally Posted by Vinno View Post
    You think it can fit maxxis ardent 2.4 or even 2.5?
    North Van/Whistler
    No idea about the Ardent question but it fit a Nevegal 2.35 just fine. Maxxis tends to run narrower than Nevegals so I'd imagine it would work
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    Couldn't say but the Schwalbe is 62mm wide across the tread on a Shimano XT rim. There looks to be around 3 to 4mm of clearance either side of the tyre. This is the biggest tyre I have run on it and for a 2.35 is much bigger than the 2.35 Kenda Nevegal it came with.
    offroader
    Dec 2008
    Are you saying teh Schwalbe 2.4 has aout 3-4mm clearance? I just ordered a set of ardent 2.4 I hope they fit.
    No I'm saying the 2.35 Schwalbe Hans Dampf has 3 to 4mm clearance. Every brand tyre has it's own way of measuring the tyre so good luck with the Ardent. I have not used one so can't say how that will fit.
    offroader
    Dec 2008
    Just got the 2.4 ardents and confirmed they fit with plenty of clearance. Dare I say it could go up to 2.5.
  1. Replies: 92
    Last Post: 2 Weeks Ago, 11:13 PM
  2. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
  3. Mach 4 Tire Clearance
    By mtnbiker4life in forum Pivot Cycles
    Last Post: 04-09-2012, 01:22 PM
  4. Pivot Mach 5 rear suspension play
    By magixuser in forum Pivot Cycles
    Last Post: 06-28-2011, 09:07 PM
  5. Pivot Mach 5 rear shock PSI question
    By JonnyB76 in forum Pivot Cycles
    Last Post: 04-19-2011, 09:58 PM
