    Mr. Chaos Theory
    Reputation: JonnyB76's Avatar
    New question here. Pivot Mach 5 rear shock PSI question
    I'm a Clydesdale clocking in at 285lbs with gear and i was curios what other beefy riders were running in the rp23.
    i'm at 220psi at the proper sag.
    Also what are you running in the fork ?
    I'm at 125psi but im not sure if i'm at the right sag and need to recheck.
    WeLcOmE tO tHe CoLlEcTiVe.
    2017 Foes Mutz
    Base of Operations NH USA
    I would say your right in the ball park and not taxing the rp23 if that was a worry. I weight 225-230 geared up and I have 195 in the rear shock and i think 90 in the fork, maybe 80. For me if i get the fork at proper sag it really feels squishy, but i left it and am really appreciating how will it eats up terrain. Its a 150mm fox talas 32 float.
    I weight around 214 lbs
    I have the low volume canisterrunning 142psi rear shock
    Talas 32 150 running 92psi... still testing but I am feeling better that I know someone in this forum is around the same psi.. what is your rebound and compression setting >
    Quote Originally Posted by mgfjd12
    I am running the same psi in my fork now, the compression is 4 clicks from full open, and the rebound is 7 clicks from full open.
