Results 1 to 20 of 20
    Pivot Mach 5.7Carbon weight
    Guys I have been trying to seach down the weight of a 13 5.7 Carbon XTR model. I have read some say 24.5lbs and others say 27.5lbs with similar tire setups. Just looking for some honesty. My local dealer doesnt have any in stock or I would go check them out. They have a Mach 429 carbon XT setup and it weighs 27lbs??? how can that bike weight so much more and it be a 100mm setup bike?
    My medium 5.7c is just shy of 25 lbs. Custom build.
    29rs are heavy!
    Quote Originally Posted by tahic View Post
    29rs are heavy!
    what componets do you have?
    Reputation: MSU Alum's Avatar
    I have a medium 5.7c, XT/XTR, XT crank and cassette, DT Swiss M1700 wheelset, stock, other than a WTB Laser V seat and Salsa QR for the seat post. Right now, I have a 2.2 Ikon rear and 2.35 Ikon front tire with a scoop or so of Stans in each. Weight is 25.90 pounds. With a 2.4 Ardent front and back and more Stans it's about 26.9 pounds. You could go lighter on the wheelset - don't, unless it's at least as stiff a wheelset, or you'll offset the beauty of the stiffness of this bike! It was a full pound heavier than my last bike, and I set 6 personal records on it the first month.
    Dec 2009
    my large is 28lbs with xfusion slant fork and fox doss post
    Quote Originally Posted by gunt pimp View Post
    what is your build?
    Dec 2009
    Quote Originally Posted by barry1me View Post
    what is your build?
    2013 5.7 carbon frame large
    stans no tube arch wheels
    xfusion slant fork
    magura brakes
    king headset
    race face turbine cranks with 32t narrow wide
    chromag osx bars
    chromag ranger stem 50mm
    chromag seat
    fox doss post
    nobby nic tires 2.25
    x9 rear derailleur and shifter
    xfusion slant fork
    magura brakes
    king headset
    chromag osx bars
    chromag seat
    fox doss post
    sounds like a nice bike!
    how do you guys like your 5.7s? and where do you ride? Are you guys going to change to a 650B?
    Mine is 27.6lbs
    Small Mach5.7c
    Fox 34 Float
    XX1
    819 on DT240
    Conti TrailKing2.2 (UST F, Protection R)
    XT Trail brakes (180/160)
    CrankBros Candy3 pedals
    FSA SLK bars
    Thomson stem
    Reverb
    Selle Italia seat
    The bike is ridiculously good.
    Small frame
    Fox 150 Talas
    King heasdset
    Formula R1 brakes
    Enve stem/rims/bar Hadley hubs Nobby Nics tubeless
    Thomson dropper
    XTR 3x10
    It's awesome
    Jun 2013
    My medium 5.7c is 25.5lbs
    Talas 150
    CK inset 2 headset
    XX1
    avid x0 trail brakes, 7" rotors
    Reverb dropper
    Stans flow ex on hope hubs
    Racing ralph - nobby nic 2.25 with stans sealant
    And will stick to my bike, not gonna change to 650b
    6 personal records in the first month - what do you think? Park City, Utah
    How you build it is everything. A 5.7c can easily be 22-30+lbs depending on what you throw on it, same thing will go for the 429.
    Quote Originally Posted by MSU Alum View Post
    good work man! congrats.
    What size rotors are you guys running? Anyone tried a 650b conversion yet?
    Reputation: laine's Avatar
    Oct 2012
    I have a 5.7c that weighs 26.01 lbs.
    size XS
    XT build (3x10)
    Fox 32 140 Float Kashima
    KS Lev 100mm dropper
    WTB Deva saddle
    Easton EA90 70mm stem
    Easton EC70 carbon riser bars
    Crank Brothers Cobalt grips
    I9 XC wheelset
    Nobby Nics (tubeless)
    Spike Spanks pedals
    Maybe if I clean it, I can get it down to 26 lbs flat.
    Reputation: grandsalmon's Avatar
    25.5 medium, w/o a dropper post
    So, I think you have all the info you need re general weights w the above build specs listed
    Don't know if it would be worth it, they have a higher bottom bracket than a Mach 6 so would be taller again.
    Feb 2007
    26lbs for my large 5.7c
    34 Talas 150
    Xx1
    Haven carbon bars and wheelset with tubeless Ardent on the front and Advantage on the rear.
    KS Lev
    Eggbeater 3 pedals
    Thomson 80mm X4 Stem
    PA Biker
    Oct 2012
    2014 5.7C xt/xtr pro build kit. Added RS reverb dropper, shimano saint pedals, Thomson X4 70mm stem, and ODI ruffian lock on grips.
  1. Pivot Mach 6 - Frame Weight?
    By HeatmiserSoCal in forum Pivot Cycles
    Last Post: 03-20-2014, 08:51 AM
  2. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  3. Replies: 26
    Last Post: 09-27-2013, 01:55 PM
  4. Pivot Mach 5.7 pivot periodic maintenance
    By LeeL in forum Pivot Cycles
    Last Post: 07-10-2012, 10:03 PM
  5. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
