Results 1 to 3 of 3
    Reputation: Rollin'in'Zona's Avatar
    New question here. Pivot Mach 4 frame/dropout stripped @ hanger bolt - 2010
    Howdy all,
    Writing about my 2010 Mach 4.
    Upon removing the rear wheel today, I found that the threads in the frame which secure the hanger bolt to the frame are stripped!
    The 10x135 I-9 bolt-thru axle holds it all in place - probably has been for a while - but obviously I want to fix this.
    On my '05 SuperMoto and '07 El Guapo, as well as my wife's '05 MotoLite, the hanger bolt is attached via the typical male/female chainring bolts.
    I'm thinking I may just ream the threaded hole in the frame/dropout from its current 8.5mm to 10mm and slide a female chainring fitting in from behind (keep it clean, fellas), thus creating the exact same setup used by Titus.
    Any comments? Suggestions? Warnings?
    Thanks a bunch!
    Reputation: Mountain_Man's Avatar
    I would use a threaded insert (helicoil, E-z Lok, etc). Of course you will need to drill and tap for the insert. If you do use a helicoil make sure you use thread locking (loctite, etc) some of the other threaded inserts already have locking material from the factory.
    Thanks for your reply Mtn_Ma. I appreciate the idea - it's got me thinking.
    The dropout is only about 3.5mm thick, though. I don't feel an insert is practical here.
    The mounting surface is so thin that the pitch of the coil is going to have to be super-fine to get any threads seated in there. This seems like a very fragile solution - likely to fail again in the future. Plus the availability/cost of a super-fine pitched tap and coil, and the headache of mounting it perfectly square...
    To make it just like my 3 Titus will require removing only 1.5mm of material from the hanger and dropout hole. The female chainring bolt almost fits inside as is...
    Quote Originally Posted by Mountain_Man View Post
  1. Pivot Mach 429 -- going down a frame size -- AM
    By DavidHarsay in forum 29er Bikes
    Last Post: 09-01-2013, 06:36 PM
  2. Replies: 4
    Last Post: 08-10-2013, 09:17 PM
  3. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
  4. Pivot Mach 429 2010 vs. 2011
    By ACMI in forum 29er Bikes
    Last Post: 11-22-2011, 06:27 AM
  5. Replies: 10
    Last Post: 10-13-2011, 12:30 PM
