Results 1 to 7 of 7
    Reputation: gulljammer's Avatar
    Oct 2010
    Pivot Les Rear Tire Clearance
    I am wondering if anyone knew how big a rear tire could fit on a Les and still have ample room for mud. Would a Nobby Nic 2.35 fit? Or if anybody that had a Les could take the measurement of the distance between the chainstays and the seatstays where the tire would pass. Thanks.
    neg rep for contributing to thread deterioration and posting useless comment. - wadafuq.
    www.fattiremassive.com
    29er or 27.5?
    Oct 2010
    Quote Originally Posted by aevanlloyd View Post
    29er or 27.5?
    29er.
    Reputation: AZ Stumpy's Avatar
    Nov 2008
    I have a 29 inch Les and am running the 2.20 Slant Sixes that came on the bike. I have around 4 mm or so clearance on either side. I'm not positive but I'd guess the 2.35 would fit just fine.
    If I recall somewhere in the Pivot literature it specifically said what size rear tire would fit.
    Nov 2008
    Here you go. Found it...
    "The real magic in the LES design is that we clear some of the biggest 29er tires in the market. Go ahead and run your 2.3s or even WTBs Weirwolf 2.5. The LES has ample clearance".
    Taken from last page here ---> http://www.pivotcycles.com/pdf/2013/Les.pdf
    Oct 2010
    Thanks. I do remember reading that but tire sizes do seem to vary from manufacturer to manufacturer. Also there is seldom truth in advertising these days so helps to collect as much information as possible. Anyway in the end I called Pivot, according to the guy on the other end of the phone the clearance between the chainstays at the tire is 74/75mm which will be enough for a Nobby Nic 2.35.
    There is tons of room
    Here is mine with a Race King 2.2 currently fitted
    Attached Thumbnails Attached Thumbnails Pivot Les Rear Tire Clearance-les.jpg
  1. EMD 9 rear tire clearance
    By EclipseRoadie in forum Niner Bikes
    Last Post: 10-20-2013, 12:27 PM
  2. pivot mach 5 rear tire clearance?
    By CupOfJava in forum Pivot Cycles
    Last Post: 04-26-2013, 12:04 PM
  3. Big Top rear tire clearance
    By andy f in forum Yeti
    Last Post: 03-23-2012, 01:35 AM
  4. 09 575 rear tire clearance
    By yeti575inCA in forum Yeti
    Last Post: 03-09-2012, 08:23 AM
  5. FTM Rear tire clearance
    By StanSuarez in forum Titus
    Last Post: 12-18-2011, 12:47 AM
