Results 1 to 3 of 3
Thread: Pivot LES Build
    Reputation: rearviewmirror's Avatar
    New question here. Pivot LES Build
    Hi all. Potential Pivot LES owner here. I'm looking for some insight into actual owners on the weight of the build. I used the Competitive Cyclist build tool for a Medium LES w/ ENVE stem, bars, M50 wheels, XX1 groupset, and SID XX World Cup fork. CC's build tool shows the following spec: 13.85 lbs / 6.28 kg. I don't believe this is possible, but perhaps it's nearly accurate? I was really hoping for something in the high 8kg range, but the CC estimate puts it in UCI legal road bike weight.
    So what is a nicely built LES really weighing in at? If they're sub-9kg I'd be happy with that.
    Draft College Republicans
    Reputation: AZ Stumpy's Avatar
    Nov 2008
    I have a size large with the factory XX1 build with the exception of XTR brakes, hope rotors, and Kenda Small Block Eight tires. Edit... Also has the QRs replaced with BlackLock thru axles and a Wolftooth chainring.
    With XTR pedals it weighs 20.5 lbs (9.1kg?).
    With a custom build a sub 20lb or sub 9kg would be very doable.
    Dec 2005
    My 29er frame wasn't very light imo, over 1400g in size large.
    My built with Pivot headset, RS RCT3 fork, Race face Next SL 32 cinch dm ring, Race face flat carbon stearer, RF Turbine stem, esi grips, carbon sdg seatpost and Formula fx saddle, LB 1650g wheelset, 2 Vredestein Black Panther extreme tires tubeless, XTR trail brakes 180mm Ice-tec discs, XO1 rear derailleur and cassette...comes at 9,95 kgs
    Recently added a wireless bike computer, now it'll be over 10kg.
    Pic:
  1. Broke my PIVOT. SO 2014 PIVOT ROHLOFF OR NICOLAI PINION HELLIUS 29ER ?
    By Williamsven in forum Clydesdales/Tall Riders
    Last Post: 3 Weeks Ago, 10:03 AM
  2. Replies: 24
    Last Post: 10-13-2014, 02:49 PM
  3. Brad's Pivot Mach 6 Build...a whopping 23.39 lbs!
    By Bradittude in forum Pivot Cycles
    Last Post: 07-02-2014, 07:00 PM
  4. Replies: 0
    Last Post: 07-21-2013, 08:58 AM
  5. Replies: 6
    Last Post: 05-04-2013, 10:51 PM
