Results 1 to 8 of 8
    Pivot headset w/ Mach 6
    I was hoping to get some more info on the "PIVOT PRECISION SEALED BEARING" headset that comes with the Mach 6. Does anyone know who manufactures it, weight, reliability, or have any experience riding with it? I'm trying to decide if I want to stick with this headset on my Mach 6 order or swap it for a CK or CC headset.
    Thanks.
    Does anyone know the frame size for the headset? what Diameter it is
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    The frame uses a 44mm upper cup and 56mm lower. Reliability of the headsets has been very good, we run them on all the demo bikes which endure a lot of riding in all conditions. I don't know the weight offhand but it's very similar to a CK or CC.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Thanks!!!
    Re: Pivot headset w/ Mach 6
    Is that zero stack compatible both top and bottom?
    Paterfamilias
    Feb 2006
    Quote Originally Posted by dielectric lab View Post
    Yes indeed!
    "The face of a child can say it all, especially the mouth part of the face".
    Jack Handy
    Aug 2013
    could some body tell me exactly wich cane creek headset model would fit my tapered fork ?
    regards
    bad reputation
    Reputation: turfnsurf's Avatar
    Nov 2007
    Quote Originally Posted by goyayago View Post
    regards
    Cane Creek 40 model.
    Upper cup is 44 mm, lower is 56mm. I just pressed mine into the head tube a day and a half ago. I made a make shift press out of a piece of 3/4" Allthread (threaded rod.)
  1. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  2. Replies: 26
    Last Post: 09-27-2013, 01:55 PM
  3. Which headset for Pivot Mach 4 2012 frame
    By speedyhead in forum Pivot Cycles
    Last Post: 07-23-2013, 07:32 PM
  4. Pivot Mach 5 external cup headset possible?
    By LeeL in forum Pivot Cycles
    Last Post: 06-18-2012, 09:30 PM
  5. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
