Results 1 to 3 of 3
    spr
    spr is online now
    Pivot 429C float 32 120mm Vs Pike reduce to 120mm
    Hi All,
    I am looking for new mtb frame(429C or Ripley).
    i am interesting in your opinion between this 2 forks and the much for the 429C.
    The pike with the same travel will be 10mm higher then the float 32(axle to crown of 531mm vs 521mm of the float 32).
    How this higher A2C data will affect climbing (smooth &technical) and cornering in tight singles?
    In the descent i am shure that the pike will perform better.
    The weight penalty is not relevant pike 1876g and the float 32 CTD 1800g
    Thx
    official eMpTyBRain
    Reputation: Hawg's Avatar
    Nov 2008
    I'd go with the Pike for sure. It's just a better fork. You'd adjust to the additional 10mm height. We buy a fork for what it will do when the going get's rough so the Pike is the obvious choice.
    ...and proud member of the anti-sock puppet desolation
    The biggest consideration is whether or not the additional stiffness will benefit you. If you weight 120lbs and ride in florida, it will probably not benefit you. But if you weight 240 and live in Moab, then you'd be a fool not to get the Pike.
    The second consideration is small bump compliance. The pike will be superior, hands down.
    <-- has a 120mm Pike on a 429c. But I'm 6'7" 265lbs and ride in SoCal, so there was no other option.
  1. 120mm Pike Solo Air available
    By peteer01 in forum Shocks and Suspension
    Last Post: 08-19-2014, 06:39 AM
  2. Replies: 37
    Last Post: 05-14-2014, 02:43 AM
  3. Fox Float 29 Evolution 120mm not travelling 120mm
    By elongate in forum Shocks and Suspension
    Last Post: 03-15-2014, 08:56 PM
  4. Need 120mm 29er Fork: Revelation, Pike, or Float?
    By El Castigador in forum Shocks and Suspension
    Last Post: 02-23-2014, 09:39 PM
  5. can you reduce the travel of a 120mm fox f29?
    By michaelo in forum 29er Bikes
    Last Post: 10-17-2011, 10:16 AM
