Results 1 to 5 of 5
    Feb 2006
    Pivot 429 New Shock question...
    I've got the stock Fox float rLC (i think) on my 2010 Pivot 429. Is there a new shock that might give it a bit of a cushier/more trail bike feel? Thanks in advance!!
    change is good
    Sep 2004
    Fox, PUSH, or Suspension Experts will retune it.
    Feb 2006
    Quote Originally Posted by DrDon View Post
    So, you think I shouldn't look for a replacement, just a retune?
    change is good
    Sep 2004
    Cheaper and adjusted for your weight, riding style and terrain. I've used PUSH with excellent results.
    Tough Guy Extraordinaire
    Reputation: Shmack's Avatar
    Send it to push! If its a 2010, it probably needs a rebuild anyway. Have them do the full Monty on the front and rear. Go with the high volume upgrade. You can pretty much get what equates to a perfectly tuned setup that runs better than a new one, for about half of the cost!
    I have all of my suspensions pushed sooner or later. If you have any questions, give them a buzz. Their customer service is awesome!
  1. Single pivot - best rear shock?
    By The Grimmer in forum Downhill - Freeride
    Last Post: 04-25-2013, 01:27 PM
  2. Replies: 9
    Last Post: 12-20-2012, 12:53 AM
  3. Single pivot shock recommendation
    By pirati in forum Shocks and Suspension
    Last Post: 05-09-2012, 05:23 AM
  4. Pivot Mach 5 rear shock PSI question
    By JonnyB76 in forum Pivot Cycles
    Last Post: 04-19-2011, 09:58 PM
  5. Lower shock pivot
    By RNBN in forum Ibis
    Last Post: 04-18-2011, 10:36 PM
