New Pivot M4x bike
Printable View
  • 03-13-2012
    iracemtb
    Nice sled.
  • 07-11-2012
    fua
    any news on delivery dates for the m4x?
  • 07-11-2012
    dan23
    Sorry for delay's on the M4X, we will receive our first shipment of frames in about 3 weeks time.
    We will post on The Facebooks about them, and begin filling all orders.
    Thanks for waiting!
  • 07-11-2012
    fua
    cheers.
  • 07-21-2012
    dog
    ... got word that my lbs should be getting an M4X shaped box with my name on it next week... i am assuming it's a full box :smilewinkgrin:...
  • 07-22-2012
    fua
    :thumbsup:
    what fork are you putting on it? i have a marz 4x, but was gonna try something longer
    maybe 120/130 rev
  • 07-22-2012
    dog
    i have a fox 831... it's in the 120 mm, mode right now but i may reduce it to 110 or 100 mm... i'll start at 120 mm.
  • 07-27-2012
    dog
    the mortal's version is here...
    ... now i just gotta finishing building it so i can ride it...
  • 07-27-2012
    kenbentit
    Finally got that bad boy! I do wish I could've done a better job with the decal tho (kinda figured I should get it shipped already :o). FWIW, I run my 831 in the 100mm setting and it's very balanced. Even feels good on DH stuff.
  • 07-28-2012
    dog
    i like the 120mm mode so far... but i have to replace the seals on my fork soon, so i will consider it then...
    Here's some "action" pics:
    the first is the M4X in its native habitat...
    the second is the habitat in which it will spend most of it's time...:D
  • 07-28-2012
    Yolden Gears
    I ran into dog today on the trails and he was kind enough to let me tool around on his mx4. Sweet bike. Dog, you really need to post some build pics.
  • 07-29-2012
    dog
    that's a good point :D... now begins the tuning process...
    here's my build picture. i has envisioned the decals as yellow, but they kind of have a greenish tint like the new safety vest color...
    BTW - anyone know why this bike doesn't have a bird name like all the other gravity oriented bikes? i am guessing because design-wise it's more like the mach series?
  • 07-29-2012
    kenbentit
    Yeah, the naming process was pretty quick since it is a 4X bike with 4" of travel. I would've gone with something like "Raptor" but M4X was pretty much decided on right away. Although it gets called "MAX" quite often ;)
    Oh yeah, the decal color was originally more yellow but we swapped to the more green tint. It does match the new DT wheels quite nicely btw...
  • 07-31-2012
    dog
    doggonnit you are right... the 120mm mode is OK for regular trail duty but on dj type jumps, it does not feel all that balanced... so when i change the fork seals i'll add a spacer or two. i think i only have one 10mm spacer in the tool box, though...
    anyone have an extra 10mm Fox fork spacer lying around? :D
    as for names of flying critters maybe the kestrel (a falcony bird) or maybe the bat?
  • 07-31-2012
    kenbentit
    Pretty sure Kestrel will just conjure up images of road bikes and lycra :o
  • 08-01-2012
    dog
    ... yeah kinda like argile prints and HT 29ers, too... :p
    edit: ha! OK, here i am giving you grief and i'm too dumb to figure out that kestrel is a road bike brand...:o:o
    now i have to eat crow.... on the other hand maybe crow would be a good name?
  • 08-02-2012
    dog
    also some numbers for those interested:
    the build weight of my bike (small frame) is 28lbs +/-
    the insertion depth of my seatpost is about 7.72" (196 mm) measured from the top of the clamp.
    I set my rebound 3 clicks from full fast (which is faster than i was thinking) so far...
    The DW-link goodness is noticeable... for instance zero bob (even considering the stiff settings) and no break dive (that i can tell)... i can tell Pivot spent some
    effort dialing other suspension aspects as well... you are going to love
    this bike if you are getting one!
  • 08-18-2012
    dog
    now that i have some time on the M4X, i can say it is what i hoped...
    i will use it mostly for trail, so i was hoping that it would pedal well (i mean for the kind of bike it is) and would have those DW linkage characteristics such as lack of brake jack, etc... so... i pedaled it up and down a "real mountain" on a loop that has about 1600 feet of net change over about 8 miles. i pretty much stood the whole way for the climb because my seatpost length is limited. the last part of the climb is up steep single track with switchbacks... i stood for all that too :D. i did not notice any bob in the suspension. it was like pedaling a HT with a little better traction. the down hill was awesome. i thought i would feel overwhelmed because this bike is so short and the suspension is so stiff... i did have to work the bike more, which added to the fun, but i did not feel overwhelmed... at one point the trail drops about 1000 feet in about 1.5 miles. there were a lot of short little water bars that the M4X ate up :D. and when i did brake (which was often :o)... no brake jack (that i noticed).
    anyway, i am thinking i'll get an adjustable seatpost... i was thinking about the KS supernatural with the lever under the seat (so there's no cable)... any suggestions along those lines?
    i did go ahead and shorten the travel to 110mm on my 831. so far i do like it a little better that way. feels more natrual on jumps, but also leaves it a little slacker which i wanted...
  • 08-19-2012
    kenbentit
    It is a pretty surprising trail bike huh? I was amazed at how much I could do with it at Deer Valley. The gnarly rock sections were pretty harsh but everything else was fine. Our demo dude just got his built up last week and he's running a KS post with remote (not sure if he has the LEV or not). I just have 2 posts setup so I can swap out as needed. The bike is so short that I can do most descending without needing to lower the post at all.
  • 12-05-2012
    kidwoo
    Snap!
    Rapid Fire: Jeff Herbertson Corking and Whipping - Mountain Biking Videos - Vital MTB
    I just found out this bike existed finally after staring at that video for about 4 views.
    So I'm bumping this beyotch up.
    Hey Ken, what's the story with availability of these things? Did it end up being a really limited run where I can't get one if I didn't preorder? I totally missed the boat.
  • 12-05-2012
    kenbentit
    It's a limited run item but we made enough on the 1st production run to fill all the existing orders and still have frames for open stock. We don't have many left but they are available as far as I know (I don't see the pending orders so I only go by what I see in the warehouse).
    Jeff's a machine huh? :)
  • 12-05-2012
    kitejumping
    Are you going to do another run of them next year?
  • 12-06-2012
    kidwoo
    I'm trying to think if I've ever even seen someone on a 20" get that dumped on a 360 table. I really don't think I have.
    It sounds like the rear shock is pretty heavily damped, do you know anything about what you guys did with the spring rate......the bike leverage rate and/or the air can volume?
    PM sent :)
  • 12-06-2012
    Mrwhlr
    Wooowooo.....20" wheels and your feet can touch the ground, no more milk crates to lug about :).
  • 12-06-2012
    kidwoo
    The only thing more pathetic than your skewed view of my stature, is your incessant need to stalk whatever I post on an internet forum.
    Get a life you fvcking dork.
  • 12-06-2012
    dan23
    The idea on this model was to make 1 run every year, if needed. The current run should last 2013 and into the next year some. So, Yes, we will make more if needed, but prolly not until sometime in 2014.
  • 12-06-2012
    Mrwhlr
    I doubt we'll ever see eye-to-eye, even if you're hopp'n mad :D.
  • 01-06-2013
    fua
    fun so far but it hasn't stopped raining for weeks, so not really pushed it to much.
  • 01-06-2013
    dog
    at least you got it a little muddy... :D
    what rear d are you running on it?
  • 01-07-2013
    J. Random Psycho
    fua,
    very nice build there.
    And at least you don't have heaps of snow around )
  • 01-26-2013
    danglingmanhood
    Such a freaking sexxy bike, are there any more available in short?
  • 01-26-2013
    kenbentit
    I believe we still have both sizes in stock, you can always call to check on availability.
  • 01-27-2013
    danglingmanhood
    Thanks, will do.
  • 01-29-2013
    danglingmanhood
    Just saw this over on pinkbike Video: Bernard Kerr - Pivot M4X - Pinkbike
