Results 1 to 25 of 25
    Mr Pivot: Why the relaxed seat tube angles?
    Seems like all the Pivot bikes have such relaxed seat tube angles compared to other brands. 73 degrees has always been the sweet spot for this 6' 2" 180lb long torso long armed rider. My XL 429C has a seat tube angle of 71.9 which in order for me to get the correct pedaling position I have to slam the saddle forward, which in turn loses me vital top tube length and forces me into a longer stem than I'd like 110. I still really like the bike, but just think it would be even better with a more neutral ST angle. Does CC cater to supermodels and Kenyans(long femur freaks)?
    Reputation: ejreyes6's Avatar
    Dec 2010
    You are using a zero setback seat post correct? Just checking don't flame. Pivot recommends a zero setback.
    Aug 2010
    It's not that simple to design a frame to match every possible size. For example I'm 6' 3" and ride a L-size 429C with a 85mm stem which suits me perfectly. So obiviously there is big variation depending your arm, torso and leg length.
    Also some people like their riding position to be really low and long (XC- style) and some like a more upright position for easier trail riding. :-)
    Here, diagonally!
    Reputation: JACKL's Avatar
    Quote Originally Posted by Xizor1 View Post
    Agree. Like the OP, I'm 6'2", long arms and longish torso, and demoed a 429 back in 2012. The bike fit beautifully with the seat in the middle of the range. On most XL bikes I feel cramped and slam the seat back. Admittedly I'm not the norm.
    Quote Originally Posted by ejreyes6 View Post
    Yep. Thompson straight post.
    Don't get me wrong, I really like the 429Carbon. But I think better geometry would make it even better.
    Here's seat tube angles from other bike makers:
    Specialized 73.75
    Trek. 73.6
    Giant 73
    Niner 73.5
    Cannondale 73.5
    Turner 73
    Pivot 71.9
    Aug 2010
    Re: Mr Pivot: Why the relaxed seat tube angles?
    Similar 100mm FS bikes (Anthem, Superfly, Epic,...) have indeed about 73 degree seat angle, but slap in a 120mm fork and you will get roughly the same 72 degrees as 429C.
    Reputation: vikb's Avatar
    The slack STA works great for me. Puts me in a good pedalling position with a decent TT length for the flats, but keeps the bike wheel base short making it agile when I am standing.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2010
    Rideon
    Curious what bike you came off
    of.
    Yep. Makes sense. Then why not design the whole bike with 120mm in mind, considering correct me if I'm wrong, 120mm is the most popular suspension/size?
    My guess is that the carbon mold was set, and they didnt want the expense of redoing it. They had already committed to 100mm. But then all us customers went 120 on the fork preference.
    Rideon
    of.
    I've owned Turner Sultan, Turner Czar, Superfly 100, Specialized Epic 100, Superfly HT, Specialized Stumpjumper HT in the last 5 years. All 29ers. Keepers were the Sultan and Superfly HT. I like the 429C better than the Sultan almost in every way, except ST angle, bottle mount location, and I'd say I prefer zircs and bushings over bearings. The 429C is a great bike.
    Had a first gen Mach 5 several years ago. Same issue with the super relaxed ST angle IMHO. One of my favorite bikes of all time was the Titus made Hammerhead 100. This was the first 100mm travel RacerX(26). CC really nailed that one!
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Slacker STAs are better for trail riding...
    To get proper leg extension the seat needs to be up and/or back. On a steep STA I feel like I'm on top of the bike, perched up high like a canary. Getting proper leg extension with pushing the seat back gives me proper leg extension, without raising the saddle too high, and keeps me "in" the bike, not on top of it.
    Another reason for slacker STAs.... bikes now have shorter stems, so you have a relatively shorter reach to the bars - sometimes too short. A slacker STA pushes you away from the bar to keep your reach more comfortable.
    Another reason... in general, larger wheels, like 29ers, often require longer stays. A slacker STA will help to keep your weight ideally centered between the two wheels.
    Steep STAs and longer stems are for xc and road bikes. I like my trail bike to ride like a trail bike.
    I run all my bikes with a set back post, including my M6. My inseam is over 34". I'm sitting way over the back wheel, and love it. Steep, techie climbs are my thing, and favorite part of riding.
    It felt weird to me in the beginning as well. To "solve" it I slammed the seat all the way forward and it felt OK. Fast forward 6 months and while cleaning my bike I noticed that my seat had migrated back over time. So I have been riding with the seat all the way back on the rails for who knows how long. It really comes down to what you are used to. Since my seat migration was slow and over time I didn't notice. Feels fine to me now.
    You should set your stem length to your standing position and not seated. Much easier to adapt your pedalling style than you descending style.
    Mar 2014
    Quote Originally Posted by Salespunk View Post
    I think this very important. The balance of the bike in the standing or attack position is really important and even more on a bike with downhill emphasis. If you change the STA without keeping the same TT the bike will feel exactly the same but the TT will be shorter; if you keep the same TT the bike will feel different. I think Chris has nailed it in many, many bikes.
    About something else: Salespunk, how is your Nomad behaving so far? Have you tell your first impressions somewhere else?
    Aug 2010
    Quote Originally Posted by Rideon View Post
    The main idea behind this bike might have been that with a 100mm fork and weight weenie parts you will get a really light, stiff and efficient XC- bike. Then on the other hand put in a 120mm fork, dropper post, wide rims etc. and you get a super capable trail- bike.
    In my opinion there is not another bike on the market in the category with the same possibilities...Anthem, Superfly, Epic etc. pale in comparison if you try to make them trail worthy. :-)
    I'm 6'6" and ride XL 429c with 17deg 90mm stem and 50mm risers. I had an issue with relaxed seat tube angles of new frames, it hurts my knee to sit too far back. I started with the RIP9 RDO, but quickly sold it after knee pain. I then demoed the Santa Cruz LTc but that also was too relaxed. Finally, the 429c allowed me to be far enough forward because the effective seat tube angle is steeper.
    Overall, just looking at the seat tube angles published by manufactures isn't the whole story. Modern FS frames have at least two angles as shown in the pic below. Therefore, manufactures list an "effective" seat tube angle, but that calculation is based on a fixed point in space. The actual effective angle will vary with the height you set your seatpost and the angles shown in the first pic. The second pic proves my point, the RIP9 RDO is listed at a 72.5deg seat tube angle and the Santa Cruz LTc is at 72.6deg. But Angle 1 is much steeper on the RDO, so with 300mm of exposed seatpost, the RDO will be 26mm further back than the LTc. In short, you just have to demo to find out what works for you, or stalk bike shops with a protractor and yard stick.
    Mr Pivot: Why the relaxed seat tube angles?-rip9-rdo-angles.jpg
    Mr Pivot: Why the relaxed seat tube angles?-niner-ltc_comparison.jpg
    Quote Originally Posted by maindog View Post
    Don't want to derail this thread, but I am settling into it now. Took a little while to get the pressures/stem length correct. I have been setting PR's on climbs and top 10's on the descents despite the fact that my fitness is off from too much work travel. Set my first KOM on it today and had the first ride where I didn't feel the need to change anything.
    Feb 2014
    Slightly OT, but with the saddle position, most importantly is it not the relationship between your knee and the pedal axle?
    eg. I've always dropped a line from just under my knee cap which should pass straight down through the pedal axle?
    Personally I'd prefer my seat back more, but if I use the method above I've got to have it all the way forward on my Mach 5.7c..
    Am I wrong/right here?
    I been wondering the same thing and now that somebody brought it up..
    Now in the days of dropper posts it is not only about finding one perfect position for you saddle. My previous bike had even slacker seat post angle that my beloved Firebird. That was one of the reasons I started looking for another frame. I didn't get the most of my dropper post. Slam it down, I really don't care where the saddle is as long as it's out of the way, but after you find the right spot for cruising/technical ride (where mine stays most of the time) and then lift it up for climbing your saddle is way back over the rear axle and that really doesn't make steep climbs any easier.
    If there was one thing I would change in my Firebird that would be a steeper STA. Was little disappointed when saw the new M6 that looks even slacker (never demoed one so this is only speculation). But yeah I know, when taking chain stay length, wheel size, travel and all other aspects in geometry into accaunt phycique has it's limitations.
    I'm going with a large 429sl partly because of this relaxed seat tube angle. I'm 5'10 but have short legs 31 inseam and long upper body with long arms. Pivot is sending me a new sl large to replace my med. 429c that had some paint cracking on the green color.
    The large will allow me to have lower seat height and I won't be so cramped on top tube with the large frame. I will go shorter stem and wider bar, this should feel better out of saddle. I have the pike 120mm fork, I hope I will love the bike even more with the large frame.
    Reputation: Bermzilla's Avatar
    Mar 2015
    We have very steep climbs where I ride. I often felt like I was sliding off the back of the bike on climbs. To correct this, I dropped the nose on the saddle. It looks funny when you see it. However, this small adjustment increased my riding performance immensely.
    Aug 2014
    oops double post
    Aug 2014
    You've probably never ridden a Kona...
    Professional Slacker
    Quote Originally Posted by Affe View Post
    Old post, but whatever.
    Don't look at the 429, it's STA is even slacker than the M6.
    The reason that Pivots get away with it is that a DW link suspension extends during climbing, instead of sagging like a Horst Link or VPP, so there's more to it than simply looking at the static (unweighted) angles of various bikes.
    Birthday Collector
    Reputation: ATBScott's Avatar
    Seat angle and saddle position is a very subjective thing. What one likes, another can hardly ride... True seat angle has always (at least as long as I can remember) been measured from the center of the BB to the center of the top of the seat tube opening. In some cases, this is "virtualized" to a point where the center of that tube would be in a horizontal line that is even with the top of the head tube. Regardless of the curves/bends/tweaks in a seat tube on a frame (usually to allow suspension mounts and links clear) it is this straight line between these two points that really matters. Some bikes account for sag or change in position when weighted when giving this measurement, others do not. Not like a rigid or hard-tail, where this does not change.
    Because Pivot has a pre-set position on their sag gauge of where the bike is supposed to be when "loaded", their angles are posted for sagged - but fork sag is not as "fixed" for this, so that may change the angle(s) a bit as well. If you sag 25-30% on your fork, you'll be sitting on angles that are damn close to spot-on what Pivot says.
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    All bike, all the time
    Reputation: BikeIntelligencer's Avatar
    To get back to OP, I too found the seat angle on my 429c (not the SL) too relaxed. Fiddled with stem, sag, etc. and have managed to get things feeling right without slamming saddle. But this is the single most frequent complaint/reservation I hear about Pivots in general. If you look at current trends, e.g. the HD3, Nomad, SB6c etc., as OP points out, Pivot is definitely alone in the mix. Feels really pronounced when I switch back and forth with the Ibis.
  1. Replies: 13
    Last Post: 04-24-2014, 05:43 AM
  2. Replies: 18
    Last Post: 11-19-2013, 05:27 PM
  3. Seat tube angles and power
    By MDEnvEngr in forum Frame Building
    Last Post: 05-05-2012, 12:17 AM
  4. Hardtails and Slack seat tube angles
    By mozami in forum Passion
    Last Post: 09-21-2011, 02:20 PM
Members who have read this thread: 4
