Results 1 to 6 of 6
    Reputation: BaeckerX1's Avatar
    Oct 2007
    Monarch Plus on Pivot Mach 5.7?
    My RP23 is due for service and with how much service costs I'm thinking of replacing with a Monarch Plus. Any issues with running this shock on this bike? What tune is recommended for the 5.7 and DW-Link suspension (low, medium, or high)? Thanks.
    Gotta get up to get down.
    LMB
    Addicted
    The biggest issue that you'll find in mounting the shock is that you'll not be able to use the water bottle/cage anymore.
    Medium tune should be the proper tune.
    Oct 2007
    The original Mach 5.7 alloy only had a bottle cage mount underneath the frame (which is basically unusable) so no worries there.
    LMB
    Jul 2013
    I owe a Pivot 5.7C with shock Fox RP23 but would like to switch to a heavier shock without loosing the water bottle option. Did you try to mount the shock with the body towards the rear? From the pics of the shock and the frame, I have still hope that it would fit but it's a matter of millimeters. Thanks!
    Reputation: JMW503's Avatar
    You'll still lose the space because the shock's external reservoir will move forward into the cage with rear triangle compression.
    So, how's the Monarch + on the 5.7c? Verdicts please......
    Is it just me or are the stock Fox RP23 that came on my 2012 frame suck!
    We Ride In God's Country!
  1. Pivot Mach 427 - Mach 4 conversion
    By kleinhead in forum Pivot Cycles
    Last Post: 03-24-2015, 02:14 PM
  2. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  3. Pivot Mach 5.7 pivot periodic maintenance
    By LeeL in forum Pivot Cycles
    Last Post: 07-10-2012, 10:03 PM
  4. Replies: 1
    Last Post: 05-21-2012, 06:37 PM
  5. Mach 5 and Monarch RC3+
    By Quadro in forum Pivot Cycles
    Last Post: 02-15-2012, 04:28 PM
