Results 1 to 28 of 28
Thread: Mach 6 Trouble
    Jun 2013
    Upset Mach 6 Trouble
    I think I may be hosed... the #18 bolt on the Mach 6 schematic located here (scroll down to Mach 6): http://www.pivotcycles.com/wp-conten...-All-Bikes.pdf has been completely stripped. I was on a ride earlier in the day and my Mach 6 was making a weird creaking noise. I thought it was about time to remove the links and clean everything, but was unable to remove this bolt because the inside just shredded as soon as I went to loosen it. Yes, left = loosen and right = tighten.
    Any ideas on how to remove it? Help please.
    Send a pic?
    Not sure I understand... Were the threads stripped or the head? I imagine it's the head. If that's the case I wouldn't panic. There are definitely ways to get that out and a good shop will be able to take care of it. I don't think your frame is hosed.
    Jun 2013
    Hard to see, but the metal just sheered off on the inside
    Aug 2010
    Easy peezy to get out. Go to harbor freight or HD /Lowes and pick up a bolt extractor kit.
    They work like a charm.
    Jun 2013
    Hopefully I can get a local shop to extract it. However, it apparently costs $180 for a new set of linkage bolts that are black. I don't know if I can buy just 1 of the older silver that are on the rest of my bike.
    Feb 2010
    Speak to Pivot. That looks like something they should see and respond to. It looks like tin foil in there. Maybe Pivot can shout you or discount a new set of pivot bolts.
    Jan 2014
    You can definitely get one bolt and it can be the light blue type - I had a bearing freeze into one and had to go that route. BTW ck your tool isn't rounded. That and not inserting all the way then turning will see the alluminium bolts shear like that.
    Reputation: SDMTB'er's Avatar
    Feb 2014
    The small parts manual indicates that bolt gets Loctite.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Try a Torx bit first and see if that'll do it. Find a slightly oversized bit, make sure it takes a little effort to get it in, and give it a go . . . worst case scenario is you strip it worse, in which case a bolt extractor will take care of it.
    You down with entropy?
    Reputation: esilvassy's Avatar
    Quote Originally Posted by 007 View Post
    the easy way for an oversized allen is to use an standard/inch sized one instead of the metric. Usually a close oversize option available
    Jun 2013
    I used a T30 torx with no luck. I called local pivot dealer and ordered 11 new black bolts and the new HD link for $280. Some of the other bolt heads on my pivot are starting to strip. I might try to use a T30 torx with JB weld and let it sit overnight.
    Jun 2013
    Just to clarify, all of the suspension bolts are standard threads, correct? None of them are reverse thread?
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Yep, no reverse threads on any of the bikes.
    Quote Originally Posted by dabuttrumpet View Post
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Sep 2004
    Just curious, you mention an HD link. care to elaborate? What is an HD link?
    May contain nuts
    Reputation: Haggis's Avatar
    How exactly are you managing to strip the Allen sockets? Using imperial keys in metric sockets? Over torquing with cheapo keys that don't engage well?
    Reputation: Vespasianus's Avatar
    Are you saying that a set of bolts for the entire bike are are $180?
    On MTBR, the reputation is infamous.
    Pivotal figure
    Jan 2003
    Here ya go. We're offering an updated link that's beefier than the original version. You'll also hear it called the "Lawill Link" after Joe Lawill (he's the one who requested a stiffer link, pro level racers can make stuff flex that others can't)
    Factory Tour: Pivot Turns out Prototypes and Assembled Bikes in Tempe, AZ
    Quote Originally Posted by stokerslo View Post
    Jun 2013
    Quote Originally Posted by Vespasianus View Post
    Yes, a set of 11 bolts for the suspension are $180
    Jun 2013
    Quote Originally Posted by Haggis View Post
    I have no clue.. I am using a craftsman torque wrench, but I was trying to loosen the bolt and take it out. I was using the correct size and i was able to remove the same bolt on the other side of the bike without problems.
    Reputation: k2rider1964's Avatar
    I've never had the issues you're experiencing but I did lose that same bolt. I called Pivot and it took an act of God to get the bolt from them. They initially said they couldn't help me and wanted me to go to my "local" dealer an hour away and order the one bolt.
    American dollars? I hope they are titanium or better!
    May contain nuts
    That is nuts... I'd expect 18ct gold plating for that money. At least those bolts come with a free shafting.
    Hello
    Reputation: charlesinoc's Avatar
    Why can't pivot just give you a dang bolt? I'm a Mach 6 owner, this sounds like a quality issue on the surface reading your post. Wish i stayed with Ibis....
    sent from my rotary phone
    Reputation: Scott@GO-RIDE.com's Avatar
    I can see why the bolts are so expensive. All of them are custom machined bolts. It's not like you can go to Home Depot and buy anything remotely like these. Machined parts are expensive to make.
    At my shop we've sold at least 40 Mach 6s. I don't believe we've had to replace a single aluminum bolt yet. I'd check your wrenches and work with a bike shop on correct torque specs.
    Pivot Firebird
    Hightower 29
    Tallboy 3
    Pivot LES SS
    Salsa Beargrease C
    Giant TCX
    Jun 2013
    Thank you for the response. The small parts list shows required torque specs, and I won't need to hit up a bike store for that. The new bolts have torque specs etched into each bolt, but torque specs aren't required when removing a bolt.
    I was able to remove the bolt by inserting a 5mm Allen key and tapping it with a mallet. It caught the "corner" and stayed on long enough to remove it.
    Jul 2013
    What size allen were you using before?? All the pivot bolts on the mach 6 are metric with normal direction threads (not-reverse threaded)
    Jun 2013
    I was using a 5mm, but the bolt was stripped except for the last little bit and I needed to use a hammer for it to catch. All is good now.
  1. Local peeps, need your suggestions: Pivot Mach 6 or Mach 4
    By w1kk3d in forum Colorado - Front Range
    Last Post: 05-07-2015, 03:40 AM
  2. Replies: 6
    Last Post: 10-13-2013, 10:04 AM
  3. Replies: 26
    Last Post: 09-27-2013, 01:55 PM
  4. Mach 4 and Mach 5.7 Frame Weights? (Alloy)
    By ccarbot in forum Pivot Cycles
    Last Post: 07-07-2013, 04:58 PM
  5. Replies: 7
    Last Post: 02-18-2013, 11:44 PM
